Reply
Thread Tools Display Modes
Old 12-16-2010, 05:42 PM   #1
YotatoySoarer95
StanceWorks Visitor
YotatoySoarer95's Avatar
  • User Status: Offline
Default How to mate a W58 to a 1UZFE(Toyota/Lexus)
I know alot of guys that simply say "F" the GS400, SC400 and many other 1UZFE powered Toyota/Lexus cars simply because they never were offered in a five speed manual. Well I have good news, you can easily turn that lazy fuel efficiant V8 auto into a torquey and very fun V8 five speed manual. If you have the coin you can even upgrade and get the Getreg six speed to fit as well(alot more money and headache though). I bought my 1995 SC400 almost a year ago and knew but didn't really care that it is considered the poor man's Supra and that it shared the same ability to have the 2JZ and be one hell of a car. I had different plans for it because I **** having a cookie cut car, one that everyone has done in Import Tuner or Super Street, so I did some research and found the bits I would need to make it happen. Now I will show you pretty much step by step how to perform the transformation on your own 400 series car. Enough chatter on to pics and tech talk.
Clutch pedal.
Bullet Cars Custom Bellhousing!
New slave cylinder
1UZFE prepped W58
TRD short throw shifter on MKIV shift adapter.
Exedy Sports Tuff Clutch Kit.
SC300 shift bezel
How to install a clutch pedal......the right way.
This kit is essential, makes it so much cleaner and its easy to use.
First pre-drill holes for your two mounting brackets and one for your clutch linkage and boot.
install the punch with cookie cut bit inside the car and flat bit on the outside and tighten till it pulls through and looks like this.
bay view
inside view
Old 12-16-2010, 05:43 PM   #2
YotatoySoarer95
StanceWorks Visitor
Install master cylinder
route linkage through pedal bracket and install nuts
route the hydraulic line to the transmission.
Remove center console and undo all connsectors to the shifter
Lift the car via jack stands, lift or whatever you have.
Remove exhaust.
Remove drive shaft
Now you can remove the bottom bolt for the shifter
Disconnect electrical connections, hydro lines and lower the transmission
Old 12-16-2010, 05:44 PM   #3
YotatoySoarer95
StanceWorks Visitor
Remove flex plate and install flywheel and clutch assembly
W58 installed and looking sexy
Interior is all back together with SC300 accoutrements:happy0034
Old 12-16-2010, 05:52 PM   #4
Jedidiah
StanceWorks Member
StanceWorks OG
Being the current owner of a GS400, this thread excites me to no end.. Thanks for taking the time to put it together!
Old 12-16-2010, 07:28 PM   #5
Zic
Spock
StanceWorks OG
Great read.
-Jón
Stretchsaurus and Pokemon.
Old 12-17-2010, 10:00 AM   #6
kartikeya
Banned
StanceWorks Addicted
Awesome DIY.
No ECU issues?
Old 12-17-2010, 10:06 AM   #7
dmyers151
StanceWorks Visitor
dmyers151's Avatar
  • Contact this user:
    Send a message via AIM to dmyers151
That's badass.
-Dale: '88 Conquest TSi
Old 12-17-2010, 11:24 AM   #8
YotatoySoarer95
StanceWorks Visitor
Quote:
Originally Posted by kartikeya View Post
Awesome DIY.
No ECU issues?
Everything runs fine, the engine is running a bit rich, but I hope to have that fixed when I get home from the desert, I had to run a NSS cancel and reverse lights are inop for the moment, nothing a pressure switch on the shifter and some relays cant fix though. And the speed sensor is off a bit but I look at the GPS for speed anyways since the wheels threw it off before.
Old 12-17-2010, 11:41 AM   #9
benz88
The French Connection
StanceWorks OG
benz88's Avatar
Awesome! only thing that bugs me is the uneven pedals in the pic. That'd drive me nuts.
Old 12-17-2010, 12:41 PM   #10
YotatoySoarer95
StanceWorks Visitor
That pic was taken with no fluid in the clutch master cylinder so I couldnt adjust it yet. It sits much closer now. lol
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
