Reply
Thread Tools Display Modes
Old 11-20-2010, 11:32 PM   #1
Pyropiggy2.5
StanceWorks Visitor
Pyropiggy2.5's Avatar
  • User Status: Offline
Default Rial Imola 2 piece old school wheel restoration
Old 11-21-2010, 11:08 PM   #2
C.Johnston
StanceWorks Regular
C.Johnston's Avatar
start by stripping the lips, thats what im gonna do on my super rs'.. then you can either wet-sand the machining grooves out, or use a caswell kit for polishing on a bench grinder or angle grinder to polish the lips..
http://www.caswellplating.com/buffs/index.html
Old 11-22-2010, 11:07 PM   #3
C.Johnston
StanceWorks Regular
C.Johnston's Avatar
There's a clear made by VHT that Caswell recommends. No experience with it, however I have seen some people clear powdercoat afterwards. It does dull it a bit, but at least it's relatively maintenance free.
Old 12-22-2010, 08:00 PM   #4
darksideracer69
StanceWorks Visitor
Looks ok, but you should have hit it with 2000 and then rubbing compound a couple times, and then polish. Doing those steps would have given you a way better shine.
Old 12-22-2010, 09:11 PM   #5
kartikeya
Guest
  • Posts: n/a
  • User Status:
I think it looks great with the satiny finish.
Old 12-23-2010, 10:51 AM   #6
motocaddy
StanceWorks Lover
motocaddy's Avatar
Quote:
Originally Posted by Pyropiggy2.5 View Post
Rear should fit well with a 235/35/18, the fender lips are already trimmed
Let me know what you guys think, I know it's not baller or anything, just want it to look clean
i absolutely love these wheels! never seen them before and really like the design! they're gonna look great once refinished.
with that said...i think you are way off on your tire sizes. here's my wife's car. 18x8 et20 w/ 205/40 and 18x9 et32 w/215/40. considering that the altima is similar in size to and looks to have even bigger fenderwells than my wife's jetta, i really think you should go with the same size tires as hers.
025garage
Old 12-23-2010, 10:56 AM   #7
motocaddy
StanceWorks Lover
motocaddy's Avatar
Quote:
this, too. you stopped polishing too early, as you really didn't get them shiny. i can still see tons of scratches in the finish. no way you can get out the 1000 grit scratches with hand applied mothers. you need to hit them with a polishing wheel and various polishing compounds. mothers is just for cleaning and maintenance polishing. also, i strongly recommend against clear coating lips. you obviously can't polish them up once cleared and it makes repairs a huge PITA.
025garage
Old 12-23-2010, 01:32 PM   #8
Pyropiggy2.5
StanceWorks Visitor
Thanks! I was lucky to find these in 114.3!
I think the Jetta and Altima have quite different wheels wells though.
Right now I have 18x9 +30 in the rear, running a fat as hell 245/45/18 tire, and it still tucks under the fender.
That's why I think a 8mm decrease in offset can be compensated by a 10mm decrease in tire width as well as 10mm decrease in profile. The Altima is a bit larger I think
Old 12-23-2010, 02:37 PM   #9
motocaddy
StanceWorks Lover
motocaddy's Avatar
i was assuming you were going to drop it more. this is stanceworks, you know. the sizes you have/are considering are not gonna allow stance. you're still way off on your tire sizes. a 235/35 does not have a 10mm smaller profile than a 245/45. that second number is a percentage of the width, not a measurement. in this case, the 235/35 will have a 30mm smaller profile than your current tires. at your current height, that's gonna look silly.
025garage
Old 12-23-2010, 07:27 PM   #10
mr sarcastic
StanceWorks Regular
what did you use to seal the lip/face mounting surface?
Old 12-24-2010, 12:58 AM   #11
Pyropiggy2.5
StanceWorks Visitor
Oh I'll drop it more , but the suggestion of 215 seemed too narrow to me, I really want to stick with 235
Old 12-24-2010, 01:21 AM   #12
Joker
StanceWorks Visitor
Joker's Avatar
I got 195/40 on 9" and u want 235/35 on 8"?
about the rim polishing... u skipped quite alot from 300 to 1000grit, the most important steps actually, the 400 wetsand and the 600 or 800 wetsand. even if u don't want bling u should remove the ugly rough grit scratches
Old 01-02-2011, 09:33 AM   #13
.Mad Hatter.
StanceWorks Regular
.Mad Hatter.'s Avatar
I actually really like that he stopped at 1000 grit...I know that's not "the norm", but I like the brushed/satin look.
Old 01-03-2011, 01:21 PM   #14
Mike36
StanceWorks Addicted
Nice work. I"ve always had a thing for Altima coupes.
Side note: I have a pair of new Falken 912s 235/35/18 & 225/40/18s for sale if your interested.
Old 04-19-2011, 08:56 AM   #15
hinrichs
StanceWorks OG
hinrichs's Avatar
what did you use to clean the barrels? lips are looking great
15 Rubicon.Coilovers.37s
05 Triumph Bonneville
Old 04-21-2011, 05:48 PM   #16
R thirty wtf
StanceWorks Newcomer
if you went 1000 1500 2000 then white rogue polish on a buffing wheel .. ~2500 rpms.. you woulda been much happier ..
Old 05-08-2011, 07:58 PM   #17
schroedin
StanceWorks OG
looks great to me...
Quote:
Originally Posted by da3bous View Post
Old 05-27-2011, 03:27 AM   #18
radiokilla
carsxhype
StanceWorks Regular
me gusta this thread. excellent work! how was your experience with wheel techniques btw? I was thinking of bringing one of my wheels to be de curb rashed there.
Old 05-27-2011, 06:17 AM   #19
Even.j
StanceWorks Regular
Even.j's Avatar
looks great! Nice work.
Old 05-27-2011, 06:56 AM   #20
Joshbm
Can someone recommend a particular wax to use on the bare polished steel?
All my mates use poorboys
Old 05-27-2011, 11:45 AM   #21
Tuck&Poke
StanceWorks OG
much better with the lips this time around. Still dont like your tire size plans though
ig: @jonnie86
Old 07-01-2011, 05:56 PM   #22
fromthelbc
Derpcedes Benz.
StanceWorks Regular
those things are awesome now. good work.
1999 Slammed W202 - RIP
1962 Ford Ranchero - Olivia (Current Project)
if i wanted to be unoriginal, i'd own a BMW.
Old 07-01-2011, 08:33 PM   #23
Curt_pnw
Here to stay
StanceWorks Regular
Lips look way better, glad you followed advice from here. I really like the wheel design too. Iooking forward to seeing them on the car.
GARAGE | THE PROFESSOR
Old 07-03-2011, 09:32 AM   #24
Anonymoose
StanceWorks OG
^This. So much of a difference when not hand finished
Old 07-04-2011, 08:03 AM   #25
G535
tiefundbreit.com
Great job on the wheels! Can you just use the bolts again?
As for protecting the lips: you can use Autosol classic or Autosol Aluminum Polish! I use the Aluminium polish like every two weeks on my polished Compomotives and just keep them breakdust free inbetween! Havent tried it yet but Chemical Guys Jetseal seems to be pretty good to protect them from what ive heard...
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
