Reply
Thread Tools Display Modes
Old 10-25-2010, 10:55 AM   #1
Stancedstratus
StanceWorks Visitor
  • User Status: Offline
Default Domestic Stance
Hey Guys, I got a 2006 Cobalt SS Sedan, that I picked up about 2 1/2 Months ago. Just starting the build right now, and only have a few minor mods to it. Just put on a set of Stance Gr+ coilovers and spun them down to lose the wheel gap. Cant fit a finger in there. This is just my winter height, but im planning to go lower in Spring next year.
Just a quick question for you guys, There seems to be a lack of wheels made in 5x110 bolt patterns, How safe is it to get a 5x112 rim drilled to 5x110? thanks guys.
Old 10-25-2010, 12:03 PM   #2
JasperThomas
StanceWorks Regular
Looks great so far.
And someone correct me if I'm wrong, but don't a lot of Volvo's have the same bolt pattern?
Stance-less
Old 10-25-2010, 12:52 PM   #3
JVC
StanceWorks Addicted
JVC's Avatar
Volvos run 5x108... now THAT is a hard bolt pattern to find decent wheels in... haha.
Redrilling is okay, but you would be just as well off running wobble bolts or adapters depending on the offset of the wheel.
Follow Me On Instagram! @jvc8790 #jvcphotography
Old 10-25-2010, 01:28 PM   #4
Turbo-sam
StanceWorks Newcomer
You don't need to re drill mate just get merc figment 5x112 then use wobble bolts they will give you the 2mm difference and slot cheaper
Old 10-25-2010, 01:59 PM   #5
benz88
The French Connection
StanceWorks OG
benz88's Avatar
cant use wobble bolts since the car has Studs and wheel bolts.
Old 10-25-2010, 02:06 PM   #6
ollycarbs
gong-club.com
StanceWorks Regular
ollycarbs's Avatar
Saab are 5x110 if i remember well and there is definitely a lot of really nice wheels on the late models, 17" and 18", you do not have to want fat dishes...
Old 10-25-2010, 03:28 PM   #7
Tuck&Poke
StanceWorks OG
  • Contact this user:
    Send a message via AIM to Tuck&Poke
Quote:
you can use wobble nuts
Need to mount stretch? PM me.
www.flat6motorworks.com
Old 10-25-2010, 03:32 PM   #8
Kielan
Kelly
StanceWorks OG
    Send a message via AIM to Kielan
Yup wobble nuts, you could redrill to 5x110, but it will cost a fair bit more, and then reselling the wheels becomes a lot harder too.
- Kielan (Key-lin)
flickr
Broadway Static
Email: kielan@broadwaystaticsuspension.com
Phone: 516-546-2129 M-F, 10-6 EST.
Facebook
http://broadwaystaticsuspension.com
Old 10-26-2010, 01:43 AM   #9
Stancedstratus
StanceWorks Visitor
I dont want to run adapters because I cant run any camber on the rear of this car with out major work since the rear axle is an ancient soild rear axle design, and adapters would push these rims out to far on the car. looking at rpf1s 18x9 et 35. they come 5x112
Old 10-26-2010, 02:54 AM   #10
Flavourless
StanceWorks Regular
Flavourless's Avatar
Use shims to get some camber outbid the rear. Vw Gus have been doin this for quiet some time
Ryan
Old 10-26-2010, 02:49 PM   #11
Tuck&Poke
StanceWorks OG
just use wobble nuts man, problem solved
http://www.serpentautosport.com/whee...ories_lugs.htm
That place has em, found it on a cobalt forum
Old 10-27-2010, 10:57 PM   #12
Stancedstratus
StanceWorks Visitor
hmm intresting, thanks man.
Quick question, how does a wobble nut work? how does it make the 5x112 wheel fit the 5x110 bolts? Just trying to gain an understanding of what i will be doing.
Old 10-28-2010, 12:47 AM   #13
andybob
StanceWorks OG
Look at this pic:
The inside of the nut where the stud threads can "float" inside the part that sits against the rim and centers it on the stud. I didn't know what they were, but it is easy to figure out how it works by just looking at the pic.
Good luck, and that Cobalt looks good that low.
instagram @ andrew_lopresti
Quote:
Originally Posted by Average_Jerk View Post
no matter how bad something is, it's usually tolerable when you're drunk. even VWs
Old 10-28-2010, 09:51 PM   #14
Stancedstratus
StanceWorks Visitor
Thanks, I understood that part about how it can move inside, but what i dont get is, how does it move the bolt so that the rim will fit on it? Wouldnt the rim still not go on the Bolt since the bolt itself isnt moving, and only the nut that holds the rim on? Maybe I'm missing something here Lol
Old 10-28-2010, 09:55 PM   #15
OSSHWA
from rust to riches
StanceWorks OG
OSSHWA's Avatar
  • User Status: Online
    Send a message via AIM to OSSHWA
I used to have a Cobalt SS. I'm WhiteSSBalt on CobaltSS.net, though I never get on there anymore. Good luck with the build. I was pretty close to doing a full on stance makeover on mine, but decided against it because I had the car for a few years and was growing bored with it. Looking forward to seeing what you do with yours though.
"A wise man once said nothing. Because wise men keep their mouth shut and avoid drama altogether."
Old 10-28-2010, 10:26 PM   #16
Guy-Bert
StanceWorks Visitor
Were those taken at Don Mills?
Old 10-29-2010, 11:34 PM   #17
ff_drift_lol
StanceWorks Regular
ff_drift_lol's Avatar
this is lowering your car, not stance. when you have character and obnoxious fitment, re post.
Old 10-30-2010, 12:22 AM   #18
Kielan
Kelly
StanceWorks OG
Quote:
This is also the builds section... No need to get your panties in a bunch there ace. His car is no more stanced than yours.
- Kielan (Key-lin)
flickr
Broadway Static
Facebook
Old 11-01-2010, 04:34 PM   #19
Stancedstratus
StanceWorks Visitor
Quote:
Yeah ive read some of your older post on .net Love what you've done with the miata, looks great man
Quote:
yup, love that place
I know, Im on Stance Gr+ coilovers, and im riding bump stops. Since these are the lowest coilovers around for this car, and I did mention this is my winter height, and it going lower in spring, chill. We get snow in Canada, lots of snow, I DD this so it will get lower in Spring
Quote:
thanks
Old 11-16-2010, 02:34 AM   #20
4dr-LS
stanced cobalt sedan FTW!
SAABot9g3
Old 11-16-2010, 04:07 PM   #21
Jersh
StanceWorks OG
Jersh's Avatar
Ironic post is very ironic...
Anyway, keep doing your thing man, lookin forward to the progress. Any wheel thoughts?
Not Low Just Slow
///M
G60 POWAR
Old 11-16-2010, 07:17 PM   #22
Tuck&Poke
StanceWorks OG
There is enough play in the bolt holes to account for the 2mm difference
Old 11-18-2010, 07:46 AM   #23
jared1988
StanceWorks OG
jared1988's Avatar
there is an uprise in cobalts! they must subside!
i was looking at a cobalt ss sedan before i got my speed3 but it didnt pull as hard, and the interior was really cheap and basic. i kinda like the yellow headlights
Quote:
Originally Posted by M.Burroughs View Post
I'd have to say this site was founded on building the cars we wanted to build, despite if the rest of the car community liked it or not. This site was founded on freedom of automotive self expression and the passion that goes in to each and every build.
This site is about doing what you like, whatever makes you happy, and not caring about what other people think...
Old 11-18-2010, 07:09 PM   #24
fletchn8n
fletchn8n's Avatar
hey we need to do a photo shoot next summer!
Old 11-18-2010, 09:33 PM   #25
Stancedstratus
StanceWorks Visitor
yes we do, i should have quite a few mods done by then. we'll plan one out.
wait till you see the rims im eyeing :P some oem goodness
Reply
Thread Tools
Display Modes
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
