Whelp, figured Id throw up a little timeline of my Volvo with whatever pictures I took here and there.
Year- 1975
Make - Volvo
Model - 244
Trim Level - GL
Original Engine - 2.0L pushrod, kjet fuel injected
Original Gearbox - Volvo M41
Alright, this car has been passed around to and from different forum members on the major RWD Volvo forum (turbobricks) for the last couple of years and has finally ended up with me (which it will probably stay for a long time). Therefore, there are plenty of mods left over from previous owners.
Current specs:
Engine - B230f from a 91 Volvo 740 (no clue how many miles), Volvo K-cam (280 duration, 12 mm lift), ported 90+ exhaust mani, Holset He351cw turbo, 4" downpipe, 3" side exit exhaust, 24x12x3 ebay intercooler, 2.5" IC piping, Forge blow off valve, Megasquirt n spark-extra 1 v2.2 board, MSD 6AL, MSD blaster SS coil, tucked wiring in engine bay, sleeved engine wiring harness with bulkhead AMP connector on firewall, Innovate LC-1 wideband, probably more dont remember
Tranmission - Borg Warner t5 from a 91 5.0, Kaplhenke Racing T5/TKO Adapter Plate, Volvo bellhousing with a big hole machined in it, SPEC Stg II pressure plate, Clutchnet 3 puck unsprung disk, Hurst shifter base, stock f-body shifter stick, Snap-On screwdriver handle shift knob, custom 2 piece driveshaft based on a 740 style driveshaft
Suspension - short strut setup fabbed by yours truly, stock strut tubes chopped 2" and welded back up, strut inserts for a 97 Saab 900, 300lb 8" Afco coilover springs, Coleman Racing coilover sleeve kit, 25mm ipd front swaybar, Kaplhenke balljoint spacers/steering quickeners, 5" OD 300lb Afcos in the back, OE 242GT rear swaybar, bilstein shocks
Wheels/Tires - Diamond Racing 16x8, 4.5" backspace, 5mm front slip on spacer, 1.25" adapter/spacers in the back (not on in the pics), off brand 205/45-16 tires
Exterior - beat up paint, roof painted satin black, 'custom' sunroof delete, saab rear spoiler, Autopal H4 sealed beam replacements, Volvo 760 wagon roof rack, Volvo mudflaps, 76 antenna ball
Interior - 2 tone (black/brown) Volvo 164 seats, plaid headliner, only fuel/temp gauges work, industrial liquid filled gauge for boost gauge, AC/heaterbox delete, windshield wiper motor/wiring/stalk delete
Have a bunch of crap I still need to do/install, but here are some pics
When the first turbobricks owner got it:
what he tried:
when he sold it, sort like that:
when the next guy had it:
after I had it for a bit, bay cleaned up, my engine in:
wiring panel mounted under the dash;
apart for suspension:
sidepipe:
megasquirt:
T5, when i took it apart for checkout:
Engine wiring harness:
steering quickener/ball joint spacer:
current (no rear spacers):
Year- 1975
Make - Volvo
Model - 244
Trim Level - GL
Current specs:
what he tried:
sidepipe:
megasquirt:
