Hi guys,
I own a 87' 318 e30 (45mm struts then)
I did not find anything as clear as I need so I'm asking a question wich has been ask plenty of time...
Will 16x9 ET20 fit in the front of the car? Or will I need spacers. I'm actually lowered around 80/55. People keep saying it still needs at least 5mm spacers, but most of them did not mentionned if they had 45 or 51mm struts, or said they had 51mm strut so that's the reason why I need your help.
I'm currently with 15x7 ET20 and the strut is around 18mm from the wheel. I might t be wrong thinking it would come 25mm closer to the strut, but I ant to be sure, and I need ome advices.
Thank you.
Thank you.
