Here i have a an Accuair Switchspeed Managment setup with Zaetech Digigauge. The DigiGauge was purchased from Bagriders late spring of this year, the setup has less than 200 Miles on it. Had the opportunity to change management and was bored with the setup and figured i'd change. I have everything you need to drop this into a car. Run a power and key on to the trunk and you're set. Here is a list of everything that is included!
Accuair Switchspeed Management
Zaetech DigiGauge (white backlit)
(1) Viair 400CC Compressor
(1) SMC Flow Control Valve
(2) SMC 1/4 Check Valves (3/8 Pictured)
(1) SMC 3/8 Water Trap
(6) Electronic Pressure Sensors (All Brand New) (5 for DigiGauge)
(1) Chrome 6 Port 3 Gallon Tank
If someone wants or needs Hardlines done, can do so if supplied material.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Here is the tank that is included!
[IMG][/IMG]
This is the hardline setup that was with the management, if someone wants hardlines done, we can work out a deal!
[IMG][/IMG]
PRICE: $1,200 With EVERYTHING included. Not looking to separate, but if necessary i will part the DigiGauge from the management, that is it!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
