GC coil sleeve question
  • GC coil sleeve question
    I'm just wondering how the GC sleeve part sits on the shock. In this case Koni yellows. In all the pictures I've seen it looks like it's just slid on there.
    The reason I ask is because I want to get Koni yellows and I already have ebay coil sleeves that are the same inner diameter as the GC sleeves. I would be able to get aftermarket springs elsewhere for less money and just use the ebay sleeves.
    Could I mount the ebay sleeves to the Konis though? Thanks!
    Instagram: surpriseitsmicah
    Builds:
    Finally found a DIY with pics.
    For others wondering, you probably cannot use the ebay sleeves as they (at least mine) do not have the machined lip.
    Here's the DIY.
    Suspension & Brakes - Koni Ground Control install - Update: ignore the part about the rack and pinion dust boots. They DID NOT work very well, due to rubbing on the 2.5 ID springs. Update 2: See below note about putting electrical tape around the shock body. From this thread: Write-up: Installing Koni Ground Controls...
    Builds:
