I know you all need some parts!
BMW 535i E28
Damn. This is amazing. What is the engine/intake/turbo set up? I want to do an intake setup like that on mine because I dislike the intake going over the valve cover. Want to run shorter and less complicated piping. Your setup it pretty much exactly what I had in mind. Never saw anyone do this unless they did an engine swap where the intake was already on the left side.
Originally posted by los02 View PostDamn. This is amazing. What is the engine/intake/turbo set up? I want to do an intake setup like that on mine because I dislike the intake going over the valve cover. Want to run shorter and less complicated piping. Your setup it pretty much exactly what I had in mind. Never saw anyone do this unless they did an engine swap where the intake was already on the left side.
the Engine is a m106 turbo from a bmw 745 e23
the intake is from a m5 e34 s38b38
and goes on ethanol =)
but i will tell you that its to small Place, i had do move Everything just to fit the m5 plenum
