17x9.5 17x10.5 BBS RS's!!!
  • 17x9.5 17x10.5 BBS RS's!!!
    I have the cleanest set of BBS RS's around the NW. reason for selling~going a new route with my car.
    Please serious buyers only. Willing to send more pics to legit buyers. $2,800 OBO.
    FS~BBS RS Refinished
    Spec~FR: 17x9.5 +28(2.5" lip), Rr: 17x10.5 +28(2.5" lip) Bolt pattern, 5x114
    Condition~Flawless, Recently rebuild & refinished; driven on for only 100miles. 10/10 condition.
    Work done~
    ~Brand New high polished lips 2.5" inches all around from tunershop.com.
    ~High gloss prismatic gold powder coated centers and hex caps.
    ~Brand New Gold plated bolts and SPIKES from tunnershop.com.
    ~Used barrels. No cracks
    Tires~Falken 512~Fr 215/45/17~Rr 225/45/17
    ~driven on for around 100 miles. 9/10 condition.
    ~front and rear tires have a few little rubbing marks from fender rubbing.
    sorry to say a negative ting. but arent your offsets incorrect? if you got 2.5inch lip all around, and a inch bigger barrel in the rear, should the rear offset not be at 40? Or your front offset be at 16?
    -Instagram@jdjurhuus
    Stretchsaurus and Pokemon.
      changing the width x amount only changes the centerline x/2 which is where offset is measured from. all you ever need to know:
      +1" lip = -12.7mm offset
      +.5" lip = -6.35mm offset
      -.5" lip = +6.35mm offset
      -1" lip = +12.7mm offset
      +1" barrel = +12.7mm offset
      +.5" barrel = +6.35mm offset
      -.5" barrel = -6.35mm offset
      -1" barrel = -12.7mm offset
      your wheels got a one inch bigger barrel in the rear, thus +12,7mm offset. difference between them.
        not all centers are created equal, some have bigger backpads then others (high disk vs. low disk)
        not saying either one of you is incorrect, just that that into consideration...
          Bump!
            ttt
              Sold!
