++**"Help me identify this wheel!" Thread.**++
This is a sticky topic.
  • Probably an older Revolution wheel similar to their 4 spokes
    Chris Lane - fifteen52 - Join us on Facebook
    chris@fifteen52.com 813.505.7910 - direct : 213.373.1552
    RML | 52 Wheels | KW | ST | B&G | Newing-Alpil | C2 | Air-Lift
    • Originally posted by electricalbox View Post
      Thank you very much! I cannot confirm that they are image wheels, but I would guess whatever image made their wheel based on is what they truly are (since they appear to be much older). Image makes great copies wheels most the time in real 2/3pc. Now I just need to figure out what that is a copy off, thank you once again a ton.
      For sure.
      Maybe drop a line to Image, they might be able to connect the dots to what their RN5 was patterned after...
      • hi everyone, help with any information on this wheel will be greatly appreciated, thank you.ive had no luck finding anything to do with this wheel online.
        -stamped on the back is PRO WHEEL 15x8.5 19lbs. the offset is a low positive to zero.[IMG][/IMG]
        • 18 Work faces but unsure about model, any help?
          Sent from my SGH-M919 using Tapatalk 4
          Instagram: @Eurow
          • I've been trying to figure out what these are for a while now and have had zero luck. All the info I have are they're JDM, 5x114, and 17x7. Thanks and appreciate the help, Chris
            • Originally posted by MikeyRa View Post
              Work VS-SD for future reference.
              Instagram: @Eurow
              • what kind of wheels are these ?
                • Crankey - They look similair to the Rotiform Classic TMB, but slightly different.
                  • Trying to figure this out... I think they are Enkei EK24 but none of the pics I've seen have deep lips like this one. Anyone know if these are legit and exist? PCD is 5x114.3 and I think these are 15x9.
                    Thanks!
                    • Originally posted by Crankey View Post
                        They kind of look like hre 542.
                        Sent from my SGH-M919 using Tapatalk 2
                        • Anyone identifies these ?
                          Seller claims that these are 5x120, 15x7.5J
                          Thanks in advance !
                          • They are called TRX and were an optional rims for the E28/E24/E23.
                            As i know they don't have a "Styling nr."
                            Normal tires don' fit on these rims, if i remember correctly, because they are 15,4"(390mm) not 15",
                            and the construction of the rims is also different from a noral rim.
                            I think they are made for the 190/65 R 390 Michelin TRX tires...
                            The tires are kinda rare and expensive...
                            • I knew about TRX sizes before, but had no idea that these were one of them !
                              Thanks for the information, they look pretty cool though
                              edit:
                              "While most 535i owners have discarded the mediocre and absurdly expensive metric TRX tires and bottlecap alloys in favor of conventional rims, this car wears a set of extremely rare Euro M535i TRXs."
                              You were right !
                              • Originally posted by Fetka View Post
                                You were right !
                                You' re welcome...
                                Does anyboddy know the name of these, or their BBS number?
                                17x8 ET30 5x110
