I'm about to get some 16x9 salad shooters for my 95 e36 I've never ran stretched tires before so I need help. I wanna run a set up like this.
Salad Shooters streched tires
I'll make it easy.
IF you go with saladshooters then you will be going with 205/45 not a 40 series cause it makes the wheel look even smaller than it is . Believe me , a 45 will size down a tad so it wont look as big as you think .
IF you go with a 17" sawblades..... like you should ..... go with a 205/40/17 . tire brand shouldn't matter to much . some tires aren't spot on as far a sizing go's but Honestly any 205 will be fine on a 9.5 wide wheel and an e36.
Originally posted by SmokemhontaS View Postwhy would you run 16s on an e36? everyone knows 17 is the ideal size. Also, if you are looking for a decent amount of stretch then a falken 205/40 should be what youre looking for
If you end up on 16s, throw in some pics, I'm interested
in for 16s on an e36. i'm about smaller wheels with a semi larger sidewallLast edited by willlarney; 12-18-2013, 02:20 AM.instagram: willlarney
big dumb e39 build
