Lowcally Famous TT build
  • Lowcally Famous TT build
    Finally moved on from my vw and got a car ive been wanting for years.
    I picked up an Audi TT225 6speed with 108k.
    I have many plans and will keep this thread as updated as possible.
    First off some pics of my old car,
    Now to the build!
    2001 Audi 225TT
    Exterior
    Votex Front Bumper
    Votex Side Skirts
    Votex Wing
    5% Tint
    Lighting
    5000K HID Bulbs
    Super White H3 Fog Lights
    Color Matched Housing W/ Reflector Delete
    LED License Plate Bulbs
    OEM Red Tails
    Interior
    ALMS Interior
    Pioneer Head Unit
    Nardi Personal wheel
    Nardi Adapter
    Momo Hub
    Glow Shift Boost Gauge
    Engine
    Revo Stage 2
    Ebay Intake
    2.5" Custom Cat-less Exhaust W/ 1 Resonator
    PowerTrak Insert
    [B]Wheels[ & Brakes/B]
    CCW LM5T
    18x9 et21
    18x10 et21 (+15mm ECS Spacers/ final offset is et6)
    215 225/40/18 S-Drives
    Adams Sport II Rotors
    Stoptech Brake pads
    Suspension
    Airlift Slam Struts
    V2 Management w/ 3/8 lines
    3 Gallon Tank
    SMS Water Trap
    Bilstein Shocks
    280c viair compressor
    ECS Upper Rear Control Arms
    Features
    Grip-Set
    Lowered Lifestyle
    Awards
    Street Life Tour 2013
    Top 100 and Best VW/Audi
    Videos
    stupid vid i made
    After Installation of Your Haldex Works Powertrak Insert
    Pictures
    Flickr Set
    Timeline
    6/18/13 bought the car 108,000
    6/20/13 red tails, ripped out rear seats, filled front plate holes 108,000
    6/27/13 timing belt, timing tensioners, water pump, thermostat, valve cover gasket, ect. 108,500
    6/28/13 custom exhaust 108,500
    6/29/13 sanded/polished headlights and tail lights, put oem bumper on 108,500
    6/30/13 sold wheels and put winter wheels on temporary 108,500
    7/01/13 removed coilovers and subs, installed air lift struts with V2 management 108,500
    7/02/13 removed rear badges 108,500
    7/03/13 oem pedals 108,500
    7/05/13 fixed exhaust, cut a few inches off so it sits flush now 108,500
    7/07/13 started rear seat delete/ tank set up, put in led license plate bulbs, put in a few more interior pieces that were missing. 108,500
    7/11/13 put in Bride seats and brackets, removed steering wheel 108,500
    7/20/13 installed momo hub, avenue wheel, aluminum shift knob, new battery and CCW's 108,500
    7/24/13 fixed window/lock problem, replaced haldex fluid and filter and fixed fuse problem with haldex. Shortened shaft for shifter 109,000
    7/25/13 got a grip-set feature! 109,000
    7/27/13 temporaryly finished trunk 109,000
    7/28/13 oil and filter change at 109,348
    8/01/13 New door speakers, 5000k HID's, and super white H3 bulbs 109,600
    8/03/13 checked alingment and its perfect even after air install, also got a check engine light, through code p1113, o2 sensor, thinking it might be because a leak in the exhaust 110,000
    8/05/13 Cut the cats and one of the resonators out (the resonator was the leak in the exhaust) 110,000
    8/12/13 found the air leak in my tank, finished wrapped the rear seat delete, ordered a quick release, and staring dissemble of headlights to remove reflector and color match. 110,500
    8/13/13 Finished headlights and installed 4 point harness belts. 110,500
    8/15/13 Installed NRG slim quick release 110,500
    8/19/13 Installed Harness Bar and rolled fenders 110,500
    8/20/13 Mounted belts to harness bar, polished gas cap and painted the hardware gold 110,500
    8/28/13 Went Revo Stage 2 and ordered new center console with cup holders! 110,800
    8/31/13 Installed new center console with cup holders! 110,800
    9/10/13 Installed Your Haldex Works Powertrak Insert 111,000
    9/17/13 Maxed out rear camber and threw in 15mm spacers 111,300
    9/21/13 Got top 100 and best VW/Audi at Street Life Tour 2013! 111,500
    9/25/13 Removed K&N drop in filter for Ebay intake 111,500
    9/30/13 Got a Lowered Lifestyle Feature! 112,000
    10/11/13 swapped out compressors cause mine cracked, also switched from 2 tanks to 1. And threw in some new oem mats, and bottom rear seat cushon 112,500
    10/17/13 Threw in a new oem DV, 1 step colder ngk plugs, and got a nardi wheel 112,600
    11/7/13 Got oem ALMS interior and sold all the race car parts 113,000
    11/15/13 oil change and frame notch 113,600
    11/16/13 Fixed window tint on drivers side door, and installed boost gauge 113,600
    11/23/13 New rotors and pads all around 113,700
    Future plans
    • powder coat wheels
    • S-Line front grille and rear valence
    • P3 Gauge
    • White vinyl wrap car and shave antenna hole, front and rear bumpers, and side markers
    • Shave Bay
    • Big turbo build
    Pics in order from day i got it to current!
    LAST UPDATED 11/23/13
    Pretty sure I remember seeing your GTI at water by the bridge. Good start on the tt cant wait to see it done
    Insta: @pantiesmores
      will never be done
      but thanks!
        Happy 4th of July
          The TT looks awesome!
            Thanks!
              dem wheels......dat stance......dat TT mmmm!
              Shit looks like butter man, great job! also I'm glad you got rid of the rear bumper too.
                Nice TT, too bad you went with those boring wheels.
                  the bbs rs's? they are temporary wheels till my cow lm5t's are built
                    Looks great. not feeling how much the tips are sticking out though
                      that was just for a test fit, exhaust isnt even bolted on yet. still got to cut out the cat and cut a few inches off the downpipe so the tips dont poke.
                        more updates
                          Awwwww yeahhhhhhh
                          When in doubt, cut it out...
                          http://www.stanceworks.com/forums/sh...ad.php?t=39445 <<<<<<< Check out my BUILD!!!!
                            lookin awesome man! cant wait for more updates!
                            Instagram: @half_lung
                              brides are finally in!
