Passion's MK3 VR6
  • Passion's MK3 VR6
    So my Bora blew up and i needed a new car and thought id go backwards rather than find something new.
    Nick and James had recently bought a mk3 cl and done a vr6 manual swap on it and i thought id grab it off them for a good price
    So here is the mod list and a future mod list ( i will do a check list and add things and remove things as i get new parts and that )
    Body
    - Vr6 Tail lights
    - Hella Dual Headlights
    - Hella Clear front fogs and indicators ( we found them in japan )
    Future Body
    - New close door Respray in same colour - MK3 hot chilli red
    - Voomeran Wide Body Flares/ Front lip/ Wing straight from Japan
    - Votex Side Skirts
    - Pop out rear windows if possible
    - Rear USDM Tailgate
    - Hella Clear twilights
    - Rear Euro Votex Valance
    - Painted Rub Strips
    - Clear Front Quarter Indicators
    - Small Mirrors
    - Bonrath mono Wiper
    Engine
    - AAA - 12v VR6 / recently Rebuilt
    - VR6 5speed box
    - Full Magnaflow exhaust
    Future Engine
    - Turbo - GT2860R
    - Cams
    - highflow fuel pump
    - all supporting mods for the turbo kit
    Suspension
    - Koni Coilovers
    future suspension
    - KW Coilovers
    - sway bars
    - Strut braces front and rear
    Interior
    - Stock standard
    Future Interior
    - MK4 bora seats or Recaro buckets
    - Short shifter
    - boost gauges
    - digital Dash
    - Cage
    - whole rear false floor with back seat delete
    Wheels and Tires
    - 4x100 Some type of race wheels got no idea what the brand is
    - semi slicks
    Future Wheels and Tires
    - TSW venoms 17x8 4x100
    - RPF1's 16x8
    and well wheels will always come and go no matter what so that'll always be changing
    there is some things im probably missing but yea
    on with the photos
    When James first bought it
    How it sits today
    So hopefully i will try to update this every time i do something new
    Anyone heading down for VITS i will hopefully bring the golf down
    Passion Garage
    http://www.voomeran.jp
    wow so a lot has happened in almost 8 months, and i completely forgot i had a thread for this car
    so here we go
    so i went to its and met up with some pretty rad people
    Mk3 by brad edwards, on Flickr
    anyways Fitted Friday came around ( farking terrible ) so good ol raymond let me borrow some wheels for the event i ended up liking them so much i bought them off him with his help and now i have a set of BBS RM001's in original 4x100
    but before then the boys test fitted nicks RS's on the golf and it looked awesome !!!
    received_1766675653351910 by brad edwards, on Flickr
    received_1239949519357862 by brad edwards, on Flickr
    received_1239949242691223 by brad edwards, on Flickr
    received_1239949222691225 by brad edwards, on Flickr
    Specs follow - BBS RM001 4x100 15x8.5" +0 on the fronts and 15x9"-6 on the rears, so they poke a bit but nothing that cant be fixed some rear camber shims and front camber plates
    received_10155277989138454 by brad edwards, on Flickr
    received_10155277989133454 by brad edwards, on Flickr
    IMG_20171210_234531_609 by brad edwards, on Flickr
    IMG_20171207_124727_077 by brad edwards, on Flickr
    20171117_211625 by brad edwards, on Flickr
    i also picked up a genuine heckeblnde, which really looks awesome and blends really well with the vr6 tails and the colour of the car
    20170830_214220 by brad edwards, on Flickr
    So life goes on
    then my oil pressure light comes on and then my motor goes boom....
    IMG_20170620_211554_439 by brad edwards, on Flickr
    IMG_20170620_211540_942 by brad edwards, on Flickr
    20170705_195242 by brad edwards, on Flickr
    as you can see the sump never cracked it just pushed up so far that it bent and shattered the oil pick up !!
    so i put a new sump and oil pick up on for testing purposes
    20170705_195245 by brad edwards, on Flickr
    20170704_214652 by brad edwards, on Flickr
    so after replacing the oil pick up and realising the bearings are defiantly gone i strip the motor and find that my bearings were completley cooked
    so i started to rebuild the motor
    lots of time and money
    and i rebuilt it all my hand all by myself ( perks of being a mechanic I'm able to use my skills haha ) it was my first ever motor build so I'm pretty proud for how it turned out
    and it runs as well haha runs really well !!
    so I'm back to work on the 15th of jan 2018 and ill be able to finish off a few things then VDUBBN.3 will be back on the road
    So during the motor build
    i got a spare block and head off stu
    i ended up using the crank from the spare block and all the pistons from the spare block as well
    all new piston rings
    all new main bearings
    all new big end bearings
    all the new main cap bolts
    all new Piston cap bolts
    all new headbolts
    I stayed with the standard mk3 head gasket as i was getting pinging with the mk4 one installed originally
    brand new water pump
    brand new oil pump
    Brand new timing chains and guides
    lots of other stuff I'm sure I'm forgetting
    IMG_20170902_145248_318 by brad edwards, on Flickr
    IMG_20170905_212941_065 by brad edwards, on Flickr
    IMG_20170911_125143_331 by brad edwards, on Flickr
    IMG_20171207_180619_503 by brad edwards, on Flickr
    received_1930020983917177 by brad edwards, on Flickr
    received_1930020967250512 by brad edwards, on Flickr
    received_1930020980583844 by brad edwards, on Flickr
    20171209_113240 by brad edwards, on Flickr
    20171211_185930 by brad edwards, on Flickr
    20171212_170121 by brad edwards, on Flickr
    20171221_185959 by brad edwards, on Flickr
    20171221_190004 by brad edwards, on Flickr
    20171222_175404 by brad edwards, on Flickr
    20171222_183015 by brad edwards, on Flickr
    20171222_183021 by brad edwards, on Flickr
    and so after all of that i was able to turn the key and she runs !!
    so not long now til I'm ripping around in it again
    So as the story goes on I'm going to be Repainting the BBS White
    i also was able to pick myself up a very very nice BBS Steering wheel for the low price of $450 haha and a boss kit off ray again ( bloody legend )
    IMG_20170826_121034_428 by brad edwards, on Flickr
    the BBS should be able make the interior look a bit nicer as well and will replace my bora steering wheel
    I've also got a new shift knob GTI golf Ball haha
    Passion Garage
      None of those photos work.
        pissed! must have taken a while to write that last post for all the photos to not work.
        Instagram - Benwalsh91
          fuaaark are you kidding me !!!
          on my computer i can see all the photos !!!
          Passion Garage
            unfortunately not
              I was intrigued, so I google searched for your thread on vwwatercooled.com
              Here's the link if anybody wants to look,
              Originally Posted by dylan8 When the motor was in the 4 door. Talking before Nick and James and before Dean who had it before them. Even know the two
              Loving the way this is going. SUBBED
                Update - all photos fixed
                update coming shortly
                Passion Garage
                  so since i last updated this thread a lot has happened
                  until i have some good time to put more effort into this thread here is what i have for you
                  i am now the proud owner of the first EuroMagic/Voomeran Car in Australia and the first "widebody" ( fender flares same s h i t who gives a f u c k )
                  ( CLICK ON VIDEO TO WATCH ME CHOPPING GAURDS )
                  20180412_185545 by brad edwards, on Flickr
                  The car/body kit is far from being done there is still lots to do !!
                  20180407_161520 by brad edwards, on Flickr
                  20180407_161510 by brad edwards, on Flickr
                  20180412_173512 by brad edwards, on Flickr
                  20180412_185525 by brad edwards, on Flickr
                  20180412_185523 by brad edwards, on Flickr
                  Fitment still isn't dialled in haha
                  20180407_125305 by brad edwards, on Flickr
                  i have 225/50/15 tires coming tomorrow that are being fitted to my now white BBS RM001's
                  lots an lots more as well, i will keep this thread updated more and more as i will have some more spare time these days !!
                  Passion Garage
                    Cant wait to see more pics, love that color on the mk3.
                    Insta Mintyhinrichs
                      Thanks mate, she's coming together, will hopefully respray this thing in a few months, same colour with some gold fleck to give it that extra pop
                      Passion Garage
                        VR6 Golf 3 are just the best.
                        Keep up the work. Can't wait to see the fitment
                          Please go real low <3
                          Nice choice of color - I'm really curious how it looks when its finished!
                          Also liked your other cars!
                            yea its been an awesome car/ starting its life as a 1.8L auto owned by a grandma since new, then to what it is today, a VR6 Built and swapped wide body beast haha
                            Unfortunately i miss judged my tire sizes and i will only be able to go so low without tires rubbing very bad on the guards without lots and lots of work.
                            knowing me i will find a way to still get great fitment for the look I'm aiming for, i can reassure you this car is going to have a few stages of the build, I'm pushing it for time as I'm trying to get stage 1 of the build finished before friday as i have to drive it 6 hours south of Sydney to the Victorian Border for its first show of the year.
                            thank you also for mentioning my old car, i wish the motor had never gone in that one too but i am grateful for the opportunity it gave me to buy the golf and what not/ i still have my old car sitting out the back of my workshop with a new motor, just need the time to put the other motor in now haha
                            Passion Garage
                              i will do my best to try and update this every night this week as i come close to finishing the 1 stage of this build !!
                              Passion Garage
