I wish I was closer, one day with two guys and every circuit on that car could be replaced and you'd have all of your electrical squared away! Were the wires replaced by the PO from what you can see or do they look original? Here's a basic diagram to go off of, only reputable one I was able to find since "some-data" doesn't go back to 66' lmao.
Also it seems as if all of your lighting in powered in series, this means both head lights share the same power source and when the circuit is open or has resistance both will go out, if one light bulb is bad the entire circuit won't work. The wiring on this car seems to be super easy and will help you get real good with electrical basics. Have fun!
