Results 1 to 4 of 4
Thread: Air Suspension ecu/relay/wiring setup
  1. #1
    Default Air Suspension ecu/relay/wiring setup
    I need help wiring my Z.....I can take a few pictures. I'm trying to figure out which lines connect to each other. And I have a solinoid block with 2 supply's in and 2 outs. I only have 1 line from the tank. Do I need to block those off with brass fittings?
  2. #2
    Default
    Try their manual, if you are not using any port on a tank it should be blocked.
    https://accuair.com/sites/default/fi...20Target_1.pdf
  3. #3
    Default
    Quote Originally Posted by Dohcser View Post
    Helpful ans
  4. #4
    Join Date
    Oct 2018
    Location
    San Diego, CA
    Posts
    6
    Default
    Do yo have any pictures of what you have done so far? That could make things easier to explain too. :thumbsup
Posting Permissions
  • You may not post replies
  • You may not edit your posts
