asking $13000.
in its current state, makes around 550hp at the wheels and over 600 ft-lbs of torque. potential for more - has made 600+hp and 700+tq. STRICTLY TUNED FOR E85.
-1990 325ic with M50 non vanos engine swap
-Precision 6162 turbo
-plastic bumper conversion
-VEMS 3.6 stand alone engine management with anti lag, boost by gear, and ignition shift cut
recently replaced:
tension straps
resealed heater box
blower motor
blower resistor
heater core
odometer gears
convertible top
econogauge replaced custom boost gauge
pioneer radio with bluetooth
fog lights (with HID kit)
front turn signal indicators
left and right grilles
kidney grille
front lip
front turn signal lenses
rear view mirror
oem shift knob
oem shift boot
ENGINE (less than 5000 miles on rebuild):
VEMS 3.6 engine management
e92 335 ignition coils
m54 3.0 crank
arp main studs
arp headstuds
bearings and rings
newer chains
newer guides
newer oil pump
newer water pump - metal impeller
oil filter housing off of a m54b30
updated power steering pump from a late e46 to increase steering assist
newer stock mechanical fan
newer stock radiator
newer belts
newer belt tensioners
newer fuel lines - including the ones around the fuel tank
newer breather hoses
new turbo inlet filter
new belts
new fan clutch
recently drained and cleaned fuel tank
custom 3" exhaust with vibrant muffler
tial bov
tial ewg (re-routed to downpipe)
custom large core intercooler
modified high beams for custom turbo velocity stacks
FUEL SYSTEM:
450 walbro in tank fuel pump
external fuel pressure regulator
80lb injectors
new fuel filter
SUSPENSION:
rebuilt power steering rack and tie rods
Eibach sport springs
upper front strut mounts
KYB shocks
control arm bushings
motor mounts - green 535
transmission mounts
rear subframe and trailing arm bushings
differential bushing
rear shocks
upper rear shock mounts with reinforcement plates
DRIVELINE:
92 525 zf transmission
new throw out bearing
new pilot bearing
new slave cylinder
new master cylinder
new clutch hose
z4 2.5 "short" shifter
shifter bushings
new guibo
e83 front driveshaft section - this is needed because the 525 transmission has a large guibo and the stock 93 325 driveshaft has a small front section
e36 rear driveshaft section
center support bearing
WHEELS/BRAKES:
CCW Reps
205/50/16 tires
newer brake pads
new drilled/slotted rotors
rebuilt/repainted calipers
This car was owned by the owner of SOUTHWEST BIMMERS, a reputable shop in Las Vegas. Car does not burn or leak any oil or any fluids. I recently spent around $2000 to get the car repainted and had the interior upgraded. There are no cracks in the dash. This is a beautiful, stunning example of an e30 with an enormous amount of power. I do not beat on this car and requires better tires to take advantage of the power. It will literally spin through 3rd and 4th.
You can contact SOUTHWEST BIMMERS if you wish to get more info directly from the shop owner, Devin. He is a reputable tuner out west.
recently replaced:
tension straps
resealed heater box
blower motor
blower resistor
heater core
odometer gears
convertible top
kidney grille
front lip
rear view mirror
oem shift knob
oem shift boot
m54 3.0 crank
arp main studs
arp headstuds
bearings and rings
newer chains
newer guides
newer oil pump
newer belts
new belts
new fan clutch
tial bov
FUEL SYSTEM:
80lb injectors
new fuel filter
SUSPENSION:
KYB shocks
transmission mounts
rear shocks
DRIVELINE:
new pilot bearing
new slave cylinder
new master cylinder
new clutch hose
shifter bushings
new guibo
WHEELS/BRAKES:
CCW Reps
205/50/16 tires
newer brake pads
