So my radiator came in and the thing is MASSIVE! I guess I knew how big it would be because my dad and I designed it, but seeing it in person is awesome. The dimensions are 38"wx18"t in a dual pass design. Fluidyne incorporated -20 AN ends for the inlets and outlets, and a -8 bung on the opposite tank that will go up to my Radium expansion tank. They also made a simple shroud that uses 2 16" Spal fans. Combined these units will pull over 4000cfm. If that isnt enough, I can upgrade to brushless 16" Spal fans that will pull nearly 6500cfm.
Untitled by Blake Olsen, on Flickr
The size of this radiator fill nearly all the space from the rear window sill to the trunk floor, and within 1/4" from strut tower to strut tower. This will greatly simplify the ductwork.
My steering wheel also showed up. 350mm Sparco with 90mm dish in black suede.
Hopefully soon I'll have more updates on the fabrication with the car.
