One Rough R32 build
  • One Rough R32 build
    Hey y'all! So I bought this R32 a little over three years ago. Coming from a 1972 beetle with whooping 40 horsepower, it was night and day to say the least.
    After every single raise and promotion I got, I swore I'd bag it. Long story short, I still could never afford it. So this is a long time coming for me.
    DSC_2027-6 final
    Now, I know most people don't consider a bagged vehicle a "build" but lemme say, it wasn't as easy as most would think. Making sure every little detail was as close to perfect first try. Making multiple measurements, I knew I'd have to redo things after the install, I wanted to keep that number to a minimal.
    DSC_4937
    First I had to decide on how to hide the compressors, tank, and valve block. Going back and forth between a false floor or just a box in the hatch
    DSC_4946
    DSC_4941
    I decided on just doing half a box in the rear. 5.5" tall so I could show the top part of the tank and the top ports where the steel braided lines from the compressors connect.
    DSC_5551
    Next was running the lines. It's no show car but I still wanted something simple and clean. I ran the lines through the trim pieces next to the door
    DSC_5555
    After that the air bag instillation began. First, we tackled the front. Taking my coilovers out and drillingthe top three holes in the strut tower to hold the air bag. We used a shoe lace to make sure the left and right lines up
    DSC_5595
    DSC_5597 and 5604
    It took us a little bit to get the three holes drilled out perfectly for it to sit in it, but around 12:30am we got it! We bolted everything back up in the front and decided to call it a night.
    Next day after work, came the rear.
    DSC_5622
    We unbolted the 4 bolts holding the rear trailing arm and lowering it with the floor jack so we could fit the grinder and drill underneath the rear perch.
    DSC_5609 and 5615
    The rear bags just fell in after doing that. We bolted everything back up and crossed our fingers!
    So after putting the wheels back on, I forgot I was running 10mm and 20mm spacers... Since I only had the extended lugs that went with them, I had to run them. I couldn't air out all the way, but knowing that all the work was completed was satisfactional enough.
    DSC_5624
    After taking them off, I was able to go a little lower. Now I still have to notch my frame, get smaller tires, and roll my fenders. Until then though, I am completely stoked on how it turned out!
    DSC_5647
    More to come eventually!
    Bagged MKIV R32
    1983 BMW R80
    @Zachbox
    Congrats man! Cool that all went well! Hope to see more soon
      Congrats man! Looks great. Any plans for wheels to complete the "build" lol jk
        haha yeah at some point I will, I just have to wait for my bank account to recover. Nothing extravagant at first though.
        Bagged MKIV R32
        1983 BMW R80
        @Zachbox
          Haha I feel you there, Aristos look pretty great, no matter what tho! Is your paint original? It's rare to see Tornado Red in such good condition.
            The grind is real man! Happy for you to get the air done, and finger crossed you won't find yourself having to fix anything
            Any other plans, or are you keeping it all secretive for now?
              ha yeah surprisingly enough it is! I ended up wrapping my roof black because that was getting kind of bad. but other than that, it looks decent!
              wheels and interior next. my driver seat looks like its about to tear soon so I'm thinking of addressing that before it actually becomes an issue. but we'll see!
              Bagged MKIV R32
              1983 BMW R80
              @Zachbox
                wish there was more detail but awesome build man! i like it!
                  Congrats man! I love the MKIV R32!
                    DSC_5714 and 5717
                    After getting getting the bags installed, I figured I'd make a trunk set up that still let my trunk be usable. I'm constantly traveling or camping. Having bags is cool and all but not being able to take my car places depending on if I needed my hatch would leave it useless!
                    Not wanting anything crazy, seeing that this isn't a show car, I went with just a basic box. I bought 9 feet of 1"x6" wood slats and made a basic box. The reason behind the 1"x6" is because technically it's only 5.5" and right in between the two ports on each end of the tank measured 5.5" perfectly! Letting me still show off my steel braided lines coming from the compressors.
                    DSC_5719 and 5722
                    After making the basic box to hold everything in place, I figured I might as well make a top to it. The hard part was figuring out how to design it. Do I want two pieces held on by hinges I could open up? Or how something maybe transparent to show everything off? Reminding myself it was no show car, I figured I'd go with an easy shelf I can just slide back and fourth giving me access to everything.
                    I bought a 1"x10" and cut it down to 40" to perfectly lay across the skeleton of a box in my trunk.
                    Making all the measurements just to find out I didn't bring the right tools home... and that it'd have to wait until I took a lunch the following day.
                    DSC_5730
                    DSC_5735 and 5735
                    Securing it with 6 brackets total, it felt sturdy. Two "L" brackets on the outside, two regular ones in the middle, and two more "L"brackets on the inside.
                    Next was to make it look like it belonged in there.
                    DSC_5742
                    I carpeted it with a fabric I found at Jo Anne's for about $5 a yard. Almost matching perfect!
                    After making the shelf, I still needed to cut two smaller pieces of wood to cover the corners next to the tank where the air lines show.
                    DSC_5807
                    DSC_5811
                    I worked a little smarter this time, borrowing somebodies skilsaw from work! Definitely made these cuts a little easier.
                    DSC_5816
                    DSC_5819
                    After making them, I wrapped them also to complete the box!
                    DSC_5871 and 5875
                    Bagged MKIV R32
                    1983 BMW R80
                    @Zachbox
                      Loving that Tank Setup !!!
                      simple and it works !!
                      Love this colour dude ( used to have a VR6 4Motion Bora in tornado )
                      Any other plans for this gorgeous car !!
                      Passion Garage
                      http://www.voomeran.jp
                        Very nice photography man, and 32 too
                          wow,just wow!
                          that colour looks awesome,your photos are great,this is good.
                          please continue
                            Thanks man!
                            It wasn't my first choice but it definitely grew on me over the years!
                            Yeah I have my eyes on a set of wheels right now, just trying to figure out what else I'll have to do to the car to make it work!
                            Thanks!! I really appreciate it!
                            Originally posted by valimihairo View Post
                            wow,just wow!
                            please continue
                            Thank you so much!
                            And I definitely will. I already have more haha
                            Bagged MKIV R32
                            1983 BMW R80
                            @Zachbox
                              gimme a sec (e28 build)
