E34 BMW 540/6 from Az
  • E34 BMW 540/6 from Az
    Hey guys,
    I'm just here soaking up info on various drops on the E34. I'm thinking of lowing my 540 by a coil in the front. To help with that muscle car look.
    I've also got a set of 18" M-parallel wheels that will need cleaning up and different tires but plan to run them eventually.
    But for now, I've got a bit more work to do:
    Cleaned up & painted, advanced the intake cams 4 degrees, retard the exhaust cams by 3 degrees. Added Headers and a few custom touches.
    Spec lightweight single mass aluminum flywheel and stage II pressure plate with kevlar full face clutch disc
    Currently cleaning up and painting the engine bay, replacing a leaking power steering gearbox and converting to manual steering. Removed ABS module, making new brake lines.
    welcome!
    damn that engine looks gorgeous.
    you should make a buildthread on here so we can see the entire progres
      Oh wow. In for this!
      I am a party pooper. I poop at parties.
        Okay, twist my arm.
