Daily Driven 1.8T Build
  • Daily Driven 1.8T Build
    Hi all. My aussie friend Seb Peek convinced me to join here a while back and I am just now getting around to it. I figured I would post up my extremely slow build of my GTI, reason being... Life and it's a daily driver right now.
    Let's start with a bit of history.
    I bought this car from a friend in Dec 2014 for a moderately decent price. I knew it needed some work but I had no idea what I was in for... The main reason I bought the GTI was because the body needed almost nothing at all (driver door has some imperfections and the front lip is destroyed), has no major rust issues which is rare for a MK4.
    That being said, I started to get to work on it right away and in typical VW fashion, I fixed one or two things and 3 more cropped up.
    To date, the repair list is as follows:
    4x Poly control arm bushings
    BFI Stage 2 Dogbone
    Retimed + new cam sensor
    New O2 sensor harness installed + new O2 sensors
    New MAF
    New coolant sensor
    New thermostat
    Brake Booster Vac Line
    2x OEM axels
    2x OEM wheel bearings
    4x brake pads + rotors
    2x rear brake calipers
    New eBrake cables + guides
    CTS Turbo 450HP rated FMIC
    Radiator + Coolant hoses
    3" turbo back straight pipe
    VC gaskets
    Cam Tensioner Seal
    Intake Manifold gasket
    Replaced various vac lines (FPR, diverter valve, etc)
    Fuel Pressure Regulator replaced
    IE VTA Catch Can
    Delete Kit
    Valve Seals
    2x Clutch Switches
    Replaced K03s w/ k03s w/ 80K + good seals
    New Battery
    New Relays
    ECU w/ stage 2 k03s tune/Immo Defeat/Emissions Deletes/2step+NLS
    Yeah. My wallet hurts...
    Anyway, the plan for it is to do a rebuild of the motor with IE forged rods and grabbing the GT3071R kit from CTS Turbo by next summer. Then I will be renting a storage unit with enough room to park the car and do work on it when next fall comes here in the states, so I can focus on doing an air ride setup.
    Now, onto the pictures!
    R32 base cluster
    Passat W8 tach face (to remove R32 emblem)
    CC Blue Needles
    Inverted Time + Mileage displays
    Lit Needle Programming (Needles always lit)
    White LED's for Tach/Temp/Fuel/Speedo backlights
    Blue LED's for needles
    Cruise Control light only on when a speed is set
    Upgraded to Jetta layflats.
    Installed an IE MBC.
    I will post more as I go along. Thanks for reading!
    @cmdshft
    2003 VW GTI 1.8T Silverstone
    Air Lift 3P / Eurocustoms Stg 2 K03s
    Well well well, look who we have here!
    Keen to see this documented somewhere now other than Instagram bro.
    IG: @sebastienaudeon
    1974 Porsche 911S
    Originally posted by TRaNz
    *pats Sebs head*
    there there.
        I love that daily! Great choice imho!
          Thanks guys! I always liked the MK4 GTI so I'm happy I was able to get one, even happier that I was able to get the car running as well as I did.
          I probably wont be posting many updates overall.
          Blew the dogbone trans side bushing from a trans fluid leak so I have a stage 2 mount from BFI ready to go in, and the trans is getting the pivot pin's o-rings replaced, the shift tower seal is getting redone and the end cap seal replaced with Syncromesh gear oil.
          @cmdshft
            Put in a new crank sensor and installed that BFI Stage 2 dogbone mount, she's running pretty mint again. Can't wait to service the trans and clean up all that gear oil on the bottom. I just hope it's not leaking gear oil from the diff seals and just from the VW emblem/pivot pins. End cap seal looks relatively decent, but also changing that as well just to be thorough. Reasons why I'm not doing the diff seals is it's hard to tell with all the current coating of gear oil on EVERYTHING (it ate the trans side poly dogbone bushing on the old one) and I don't know anyone that I can borrow the axel flange tool to do the job.
            Also have a rear wiper delete plug coming next week as well as a new FIS cluster to replace my custom MFA cluster I just did (I neeeeeeeeeed VFIZ), and I have a slick Evo Pro series digital boost guage coming as well on Monday. I should have it wired up by that night or Tuesday, I will post some pics of everything before and after.
            @cmdshft
              Welp. Looks like another turbo blew on me. Tons of white smoke on startup, didn't go away till I started driving. That's what I get for a $10 used OEM turbo. Can't really complain at all.
              This morning's cold start had no smoke at all. Wondering if it was just a lot of condensation that built up and it just picked up the hint of oil from whatever has been in the exhaust since before I did the valve seals.
              @cmdshft
                Digital gauge done!
                @cmdshft
                  Wiper delete done!
                  @cmdshft
                    Already upgraded to an FIS cluster. Love it.
                    @cmdshft
                      Installed an AEM air/fuel ration gauge (lambda face with AFR digital display). Still need to weld in the bung and run the actual sensor wiring and the sensor itself, but the gauge is functional.
                      Getting the exhaust repair this weekend (again), large hole in the back from 2-step blowouts, rust doesn't like that at all. Also... somehow managed to lose the dual tips on the roads somewhere... Had no idea they were never truly secured to the system. ¯\_(ツ)_/¯
                      @cmdshft
                        Some updates:
                        Purchased a cheap stainless steel 3" turbo back from ebay. Installed everything except the muffler (used it's tip though) and it sounds way better that the straight pipe. I was pleasantly surprised.
                        With it, finally got the AEM afr gauge working and I'm glad to be able to see real time rich/lean conditions.
                        Installed a new front valence. Stuck with the OEM one for now, eventually I'm getting an R32 bumper. It was a pure right cunt getting the old broken bits out before putting the new one in. Also took a minute and clipped off those awful broken fins in the center section of the bumper cover. With a new 3-bar grille, it doesn't look half bad. I still have the notch in the bonnet, though, which does look plain dumb. In the meantime, I'm gonna look for a nice hood bra to cover that up until I can get the notch actually taken care of.
                        Replaced the differential seals finally as well, transmission was leaky as fuck from there. Didn't get a chance to wipe things down tonight, so hopefully the puddles I was still leaving are just the old fluid I never wiped off dripping to the ground. I'll know more in the morning.
                        Car just needs coilovers soon really. Then a few interior bits and it's the road to rebuild and big turbo.
                        @cmdshft
                          cars progress is looking pretty good
                          I do have a couple of questions though
                          is the larger pipe going over the valve cover from your fmic?
                          and how difficult was it to setup the electric boost gauge?
                            Thank you. I'm excited to see how it will look lowered.
                            Yep! If you're curious, it was made by CTS Turbo, and they used a photo the shop that installed it took as a example photo on their product page! 😁
                            It was fairly straight forward. Power from key on switch, ground it and then connect the wiring harness to the boost sensor into the gauge. Same with the AEM afr gauge.
                            @cmdshft
                              Love the cluster!
                              - Renato
                              TWMPerformance.com | TWMShiftKnobs.com | GodSaveTheManuals.com
