Results 1 to 6 of 6
Thread: Help me get set up for garage painting...
  1. #1
    Join Date
    Apr 2016
    Location
    Forest
    Posts
    9
    Default Help me get set up for garage painting...
    Greetings everyone...
    I am looking for some guidance. I have done a few things with paintscratch.com aerosol cans in the past and I'd like to find out about making the shift towards a budget paint gun setup and everything else that entails.
    - Would like to know your rec's for budget equipment.
    - What do I absolutely need?
    - What do I need for an air system?
    - Rec's for paints, flex additives, primers, etc.
    - Any great educational youtube videos - there are a lot out there. Surely some better than others.
    I hope to paint only a couple bumpers, sideskirts, mirrors, nose panel and hood. No body work, maybe a little light surface rust remove.
    The car is black, so of course it will require some real dedication in order to be done right.
    Thanks a lot everyone.
  2. #2
    Join Date
    May 2018
    Posts
    1
    Default
    If you're hoping to save some time while using your tech but don't know where to start, we have you covered with this roundup of skills. intrusive technology
  3. #3
    Join Date
    Jun 2018
    Posts
    1
    Default
    Smartphones: Buy Smartphones Online for low prices in India. Find popular Smartphones from Samsung, Apple, Micromax, HTC & more. game reviews
  4. #4
    Join Date
    Sep 2009
    Location
    Lancaster, CA
    Posts
    679
    Default
    Painting with a compressor at home is all about having a moisture separator and a good amount of cfm. Max PSI is nice, but a high enough cfm will ensure you don't spray at an inconsistent volume. Hose your work area down before you bring the parts in to paint so that all dust particles stick to the floor when you walk around the garage. You can buy sheets of steel/aluminum at the hardware store to fine tune your gun/psi settings before you spray your actual parts.
    -1993 535i/5 NA-T
  5. #5
    Join Date
    Apr 2016
    Posts
    62
    Default
    a 1.0-1.4mm HVLP (high volume-low pressure) gun will do well, theres lots of guns that will paint at 20-25psi. you'll need about 4-5cfm if you want consistent sprays
  6. #6
    Join Date
    Oct 2018
    Posts
    1
    Default
    All things considered, the appropriate response is entirely - instead of producing extravagant textual styles, this converter makes extravagant images. The clarification begins with unicode; an industry standard which makes the determination for a great zalgo generator
Posting Permissions
  • You may not post replies
  • You may not edit your posts
