Proper technique for polishing polished lips
  • #16
    I will keep that in mind!
    • #17
      I use Autoglym Metal Polish every second carwash.. takes some brake dust etc dirt off them..
      Now: MB W211 320cdi
      Ex:MB 190E M50, BMW E39 530d
      • #18
        After cleaning my wheels I add a little wheel wax or carnuba wax to the wheels to keep them clean.
        • #19
          oh and another tip my friend fucked up the lips on his Works when the carwash dude left degreaser on them. Stains the shit out of raw metal
          ig: @jonnie86
          • #20
            Yea.... that was a BIG no no...
            Brandon, you could've just called me
            I would apply a synthetic sealant before I assemble the lips. Good protection for around 6 months. Me being the meticulous detailer I am, I'd probably disassemble them every 6 months and reapply. You can reapply while assembled, but getting it around the bolts is a bit difficult to do...
            Q-tips are your friend :]
            to clean: P12S wheel gel with your washes. It clings to areas between the bolts since it is a gel and not a liquid, really nice and easy to use.
            Get a toothbrush and scrub between bolts for extra "squeaky-clean-ness"
            Meguiars mag aluminum polish works well too! Now that you have that damn PC, throw on a 3.5 inch backing plate, 4 inch Lake country spot buff ccs pad, spread some mag aluminum polish on that beezy, and go to town
            If I see your style 5's dirty at any point, I will be a VERY sad panda
            <3
            "Auto Detailing by Jake," servicing the Southern California auto enthusiast community.
            Detailing Dough --> College dues. Which leaves $____ for e36. D'oh.
            • #21
              Originally posted by VIPME View Post
              what kind of quick detailer do you use>?
              I keep my wheels pretty fresh all the time...to avoid dust...
              but was thinking of using like a mothers once in a while....
              just curious on the detailer..
              just meguiers quick detailer, the one in the red bottle. works perfectly for keeping them fresh.
              • #22
                I found this little guide,,,check it out
                • #23
                  i got secrets up my sleeve.
                  300 grit. go around the lip, then sand down into where the face of the wheel is, then sand in an x pattern then around the lip again.
                  repeat this step with 500, 600, 800, 1000, wetsand 1200, 1500, 2000 and 2500 if you can get it.
                  get a rubbing compound i used a turtle wax rubbing compund. its in a white container. smear it on then rub it into the metal then clean it off.
                  use a ryobi drill attachment thing. there are 3 different compunds in it go from light to dark. instructions are on the back of the package.
                  use a blue magic metal polish (dont smell it it will make your head burn) and done! your lips are polished.
                  • #24
                    Originally posted by SeanDub View Post
                    Sand the piss out of them, then polish the fuck out of em. Then they will be piss and fuckless
                    That's good stuff.
                    • #25
                      Have any of ya'll tryed this stuff?
                      Aluminum Wheel Polish, Chrome Polish, Sealer, Stainless, Fiberglass, Lexan, Magnesium, Brass, Copper. Remove surface Rust from Chrome, Stainless,& Bluing. Easier to use, than Mothers, Zephyr Pro40.
                      I used it w/ steel wool on my chrome window trim that was stained and faded to a white haze and it did a great job of polishing it back out like new. Everything else I used couldn't touch it but this stuff did the job. It holds up well, been about a year now. I'll reapply it with a rag every so often and the shine gets better each time.
