Wouldn't worry about upgrading those camber arms they haven't really given anyone any problems and as for the BC racing upgrade talk if you go up in spring rates you might actually blow through your shock towers. The racelands are pretty comfy and will get you low enough, especially with bags. Those camber plates are what I used and can get some good adjustment but beware when you air out all of the weight on the car may bend them unless you lay frame. Sucks about the bag kit man try to tap those threads and make that shit work!
Elbenzo // Bagged '92 190E Project
Originally posted by Stupid KidI need the weed in advance i can't ride my bmx across the ocean unless im high
Also if you're trying to lay frame those bily rears will stop you before you hit the ground
Really excited for this project! I am doing something similar to my 124 wagon, but I went with the Gnarlow cup kit and ss5 bag. You are on the right path, looking forward to the finished product!
Originally posted by 190Evan View PostAlso if you're trying to lay frame those bily rears will stop you before you hit the ground
Thank you! I hope to have some real progress soon instead of just this parts gathering. Once Bagriders confirms my return I'll be sending back the UAS bags and having them replaced with the SS5's (If they ever confirm my return).
In regards to shocks, Evan is using the Ford Ranger front shocks (in the rear), other's have used Saab shocks. But keep in mind that generally speaking Performance and laying frame don't typically go hand in hand.1992 Mercedes 190 E | 2002 DTM Inspired IS300 | IG @ DAAR_CREATIVE
Originally posted by DropCulture View PostWhat would you recommend that offers amazing performance yet allows you to lay frame? I was told the toxic shocks from summit racing are the best?
I HAVE UPDATES!
- Sending back the Bilstein B8's and replacing them with KYB Gas-a-just rear struts from a Saab 900. Seems like it'll be the perfect middle ground between the B8's and the Ford Ranger front shocks. I'll still be able to hit the ground from what I've researched.
- Bagriders still hasn't fully agreed to take back the bags that I received because "that's how they all are". This isn't a good answer, just because a company provided you with a product that doesn't look good, and you didn't question it or send them back doesn't mean that your customer doesn't reserve the right to returning the item and exchanging for something better. (Emails still being exchanged)
- I got some rimzos until my ACTUAL rimzos are done-zo's! Found these on the local classified for $650 but talked him down to $450. Boy do I love coming across rare, quality stuff!
Here's the deets
From what I've researched they go by Centra/Ronal T31/R31's or ARC Alurad (what is stamped on the wheel). Long story short, there's like a billion size variants, and I seem to have picked one of the most rare variants in sizing. They measure in at a 16x8 +11 (which is rull good).
PICTURES!
Centra T31 // ARC Alurad by David Arellano, on Flickr
(nub)
The good:- They be rare
- They're a fantastic size
- They have all four center plates
- They don't have any bends
The bad:- They've got some battle scars
- No lock and key was included
- The lock and key are stupid rare (been doing research all day) and stupid expensive (about as much as I paid for the wheels)
- The last last owner put silicon all around the plate to seal them on (scary, thank god they didn't fall off). (not really a big deal)
- One of the plates is missing the metal seating nub thing on the back (I should be able to have one machined)
I'm going to have to get creative with the lock and key setup. Here's what the lock looks like on the cap. The inner edge of the wheel has a seating groove where the nub seats and this lock rotates to secure the opposite side. Also, please note that there are two different styles of locks. The other style is your traditional bolt threading in to a tapped hole in the lug dish of the wheel. Mine will not work with that setup.
This one cap is listed at $350 with the single lock and no key.
This set of keys is for a Sierra RS Cosworth but they look to be exactly the same. Also listed at $350 and no guarantee that they would even work with my wheels.
Another set of Cosworth locks and keys but these come in at $750
Last edited by JDMexican; 05-25-2016, 10:55 AM.1992 Mercedes 190 E | 2002 DTM Inspired IS300 | IG @ DAAR_CREATIVE
Got my Saab 900 KYB rear shocks today!
Elbenzo's KYB's by David Arellano, on Flickr
Also finally got around to unboxing the OCD (Only Charged Dubs) suspension kit today! The quality of these items are superb and I'm really glad that I went with their kit (even after the troubles with Bagriders). I'm really really bummed that I won't be able to make it to Wuste with the car but it'll all be okay once I get it all installed and take a step back to look at it.
PICTURE DUMP!
Only Charged Dubs 190E Kit by David Arellano, on Flickr
Also unboxed my Exo-mount setup! I'm probably going to mock up my tank setup to make me happy/sad until my damn wheels get done. Hopefully I get some updates on them soon. I've got 2k sitting out there with nothing to show for it yet.
Exo Mount by David Arellano, on Flickr
Going to have to make an adapter plate or drill some hole so I can mount my Airlift manifold to this
Exo Mount by David Arellano, on Flickr1992 Mercedes 190 E | 2002 DTM Inspired IS300 | IG @ DAAR_CREATIVE
Lemme know how those shocks end up working for you, may pick up a set and raise my car a little until I can get my alignment sorted. Also are you planning on welding on a sway bar mount to those custom FLCA's? might handle a little weird without it but I'm not sure. I used to have one of those caps but I may have thrown it away lmao wish I knew how much they are worth I'll take a look after school and see if I can find one for you. If I can find it she's yours if you pay shipping.
Looking at these two photos I'd say my rangers are about 16-17 inches, didn't realize the size difference wow
Originally posted by JDMexican View Post
Awesome car dude. Goes for both of them.
Originally posted by Leeroc View PostI think you're going to need ss5/6's.
A friend of mine has the OCD kit and ended up swapping over to ss6 bags because the UAS bags were too wide. Same situation for me but I have the gnar low kit.
Originally posted by TechnoV View PostGot the same coilovers on my 135i. Love them!
Originally posted by Gab87 View PostVerry nice parts
Speaking of nice parts! I got some new parts in the mail yesterday, all the way from Bulgaria. Can't wait to take some shots of what I got and show it to you guys!1992 Mercedes 190 E | 2002 DTM Inspired IS300 | IG @ DAAR_CREATIVE
Here's the things I got from the Bulgaria.
Hella Magic Color smoked tailights! Hella brand, that is. Picked these up off of eBay when I had absolutely no intention of getting new tail lights yet. But then I saw these and I had to buy them, if it wasn't these it was going to be the cheap smoked ones but I still like having genuine items.
Also, I'm going to start searching up pricing for chasing LED conversions and these very well may be the basis for that conversion. Hopefully I don't upset too many purists by doing that. (Really I don't care)
Hella Magic Color Tail Lights by David Arellano, on Flickr
Neat
Hella Magic Color Tail Lights by David Arellano, on Flickr1992 Mercedes 190 E | 2002 DTM Inspired IS300 | IG @ DAAR_CREATIVE
