Finished up my fuel system plumbing. I have to mount the bulkhead fitting to the sender cover and install the fuel pump and that can get checked off the list.
feed line plumbed up
return line
had to do alittle massaging to fit that big ass 90* -8
and all set. the return from the FPR is ran to the stock feed hardline back to the tank.
then subframe went back in and i threw everything on for a couple progress pics
engine came out again to finish up the bay and get started on the chassis harness. threw in a new master cylinder because the stock one was leaking and then bent up a new passenger line which is much neater than the stock one.
return line
