Cougar House Garage Project Sacrilege Ford Super Duty
  • Got the tool box back from my friend Eric with the TIG welder he mad mounts for the tanks and a aluminum battery box
    Now its time to setup the Accuair electrics I like these MIDI fuses much easier to work with then maxi fuses
    To compressor relay
    Soldered and shrink tubed
    Accuair ECU 12volt
    The white wire is my ground like toyota uses
    Website: http://cougarhousegarage.com/
    Check Out Our Facebook Page For More Pics and Videos
    • I installed the Destroked 60-1 tone wheel for the tech
      2011-2015 B-piller panels
      The ford adaptor brackets for the 2011-2015 B-pillers panels
      Lower B-piller panels
      Time to bolt down this tool box
      Stainless steel 3/8 button head bolts and nylocks
      I got some AN fittings for the transmission cooler lines and finally some vice jaws
      • Started building the valve harness
        I love expandable mesh loom and shrink tube
        I arched the grounds together and ran through the harness to near the Accuair ECU
        Controller harness, headlight wire and ignition wire need to be ran into the cab
        • Love your updates and the quality of your workmanship
          • Originally posted by The Simps View Post
            Thanks man
            • Heres the pics of the new glass that went in last week,the rear window is a solid with privacy tint
              • Where did you get the expandable mesh loom? It looks like you used a bunch of it. It makes your wiring look so clean!
                • loving this,
                  that expandable mesh looks great! so much better than normal shit suff
                  • Originally posted by Fleetlin49 View Post
                    Originally posted by Lukey View Post
                    loving this,
                    Thanks guys I think so to, I got if from delcity.com
                    • I got the custom made radiator and intercooler back from Doug at Up Garage in Tacoma,Wa one off
                      • Loading up for the first car show the trucks going to
                        • Thanks for the link! Looks like they have a lot of good stuff. What show are you guys going to?
                            We went to the 4wd swap meet show in puyallup Wa on march 6
                            • Heres the pic's of the trucks first show
                              What do you guys think?
                              • I almost like the railroad service truck look haha.
