Hey all! im kind of finished with my restoration on my rally car, just missing the engine, then i found another ke20 with a 2tg ( 1,6 dual 40 solex's DOHC) with lots of parts...
Here it is when i bought it 3 days ago.
pushed in into the barn
it currently has no front suspention but this is the plan..
9x16 rondell wheels, 1 inch spacers 225/45-16 streetslicks
nothings really attached, its just mocked up..
Rear wheel is a bit more intresting... the lip of the rim is cut off, im going to widen them wil get lower in the rear! with 265/45-16 streetslicks
rear rims
here you see the lip, they are Alu so a friend is going to weld them going to add 5-10 cm
i also have this ducktail..
shortned struts with AW11 MR2 rear dampers
here is the engine i got with it, im going to put a worked orignal engine in it instead, this is going in my rally car
here you can see the rear tires ontop of the orginal tires
and then just a quick pic of one of my other corollas, the RallyRolla be sure to like my facebookpage https://www.facebook.com/RallyRolla
rear rims
