Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Clunking noise coming from front left driver side
    Sep 2009
    Houstatlantavegas
    1,024
    Default Clunking noise coming from front left driver side
    So figured most of you on here would know what problem I could be having hence we all run slammed cars either on bags or coilovers. So the past few days I have been hearing his clunking noise coming from the front left coilover. Only really happens when i hitt a bump or dip in the road at low speeds. Or when I push down on the front left I can hear the clunking noise. Ofcourse tommorow I am going to jack the car up, remove the tire, and look up there and see if I can see anything. I am running Tein Basic Coilovers on there have had them for probably 25,000 miles give or take. I seem to think its either my upper ball joints, or front sway bar links, maybe? Any other ideas maybe a cracked spring? Any ideas would be appreciated.
    -Jay
    What car is it?
    ig: @jonnie86
    What is it like when you turn the wheel?
    Sep 2009
    Houstatlantavegas
    1,024
    Its a 06 Acura TL, and as far as when I turn the wheel doesn't make any noise at all when I turn. I jacked the car up today and removed the rim, checked the cv boots, the sway bar endlinks, and the upper ball joints all seem to be fine. Nothing is leaking anywhere. The top hat is secure and checked the bolts on the top hat. Checked all the bolts on the coilover, everything seems to be intact, the spring on the coilover is still intact no sign of any cracking. I almost want to think its the coilover it self bottoming out every single time I hitt a dip, or bump in the road. They are maxed out in the front and they are tein basics with absolutely no stiffness to prevent that.... any thoughts?
    -Jay
    It still shouldnt clunk if the bump stops intact. Maybe a solid thump but not a clunk.
    Feb 2010
    Maryland
    180
    its probably the hi-lock is loose on the top of the shock, i just had to pull my coils off and tighten them for the same clunking noise you are talking about.
    inspection:
    when you take the coil over out. push down from the top against the coilover in its upright position (the way it sits on the car) if it clunks or moves back and forth at all you need to tighten the hi-lock.
    hi-lock:
    where the bump stop attaches to the shock there is a hex head on the top of the shock rod that needs to be tightened all the way down until your about to break the allen key this should eliminate youre clunk.
    could be a blown shock or upper control arm hitting frame.
    Sep 2009
    Houstatlantavegas
    1,024
    Quote Originally Posted by SlammedSuzuka View Post
    Checked the shock its all intact nothing is blown, a buddy of mine said the same thing that its probably my upper control arm hitting the subframe. I am going to take the coilover a part today and see about that hi lock seeing if that needs to be tighten again.
    -Jay
  9. #9
    Feb 2010
    Maryland
    180
    Quote Originally Posted by Jay Z. View Post
    well good luck, i really dont know about honda/acuras but i assume it cant be that much different from volkswagon audi parts. i figure you would notice a blown shock a little bit more than just a clunk over small bumps
  10. #10
    Sep 2009
    Houstatlantavegas
    1,024
    Quote Originally Posted by lowpoke View Post
    You were quite right my friend the hi-lock on the top of the coilover was so loose I could thread it off the coilover it was so loose. Ended up just taking a impact to the top of it and re-tightened it and no more noise. So thanks again for the input, greatly appreciated Guys like you is why I love this forum, you all know whats up
    -Jay
  11. #11
    Nov 2009
    NY
    1,227
    I was going to suggest checking the top strut nuts, good to see that was all it was haha
    Flickr
    Quote Originally Posted by Kielan View Post
  12. #12
    Feb 2010
    Maryland
    180
    its weird that they would just come loose like that unless they werent tightened down all the way in the first place. im putting red locktight on mine just for safety sake. i suggest you do the same unless you want to do all of this over again in 25k.
  13. #13
    Sep 2009
    Houstatlantavegas
    1,024
    Honestly dont think it was tighten down all the way when it was originally installed. But I am actually going to do that probably tommorow. As far as put that locktight on it. Thanks again for the input in this all.
    -Jay
  14. #14
    Feb 2010
    Maryland
    180
    yeah i tightened mine up last night and i am so much happier, haha i not only feel safer but it rides a million times better!!!
  15. #15
    Nov 2009
    NY
    1,227
    I've had mine loosen a couple of times, the thunking noise is pretty distinct and it's an easy fix at least
    Flickr
  16. #16
    Feb 2010
    Maryland
    180
    Quote Originally Posted by aar0n. View Post
    so i think i fgured it out, if you keep adjusting and re-adjusting the coils, it of coarse is going to loosen over time also as shocks wear, that could cause play that would eventually rattle that nut on the hi-lock to loosen over time.
  17. #17
    Sep 2009
    Houstatlantavegas
    1,024
    That would make perfect sense now, I adjust mine all the time.
    -Jay
  18. #18
    thank you to this thread!! i just fixed my clunking issue i have been having.. although i am on bags.. looks like my top strut nut got loose and was causing the clunk.. finally no more clunk clunk clunk.
    thanks guys!
  19. #19
    Sep 2009
    Houstatlantavegas
    1,024
    Quote Originally Posted by TommyT View Post
    thanks guys!
    Glad my problem has helped other people too!
    -Jay
  20. #20
    inspection:
    hi-lock:
    Great problem solving guys!
    Which is the hi-lock though, I quite dont understand? Does someone have a picture of this perhaps cause I dont get what and where this is... Thanks!
  21. #21
    Sep 2009
    Houstatlantavegas
    1,024
    Quote Originally Posted by ToTo View Post
    Its the nut on the very top of the strut is the best way to explain it.
    -Jay
  22. #22
    Oh cool, all right, got ya! So basically tighten that very top nut all the way down as much as possible?
  23. #23
    Nov 2009
    NY
    1,227
    You want an impact gun to do it. Tightening it by hand will not be enough
    Flickr
  24. #24
    Feb 2010
    Maryland
    180
    i cant use an impact wrench, mine has an allen key that has to be inserted while tightening it, kind of like a gimbal bolt. so i can only hand tighten mine with a high-lock set, basically a hollow ratchet the max tq i can put down with it is about 120 ft lbs, but usually some lock tight or hitting it with a piece of solder while keep it from turning and just re-heat the solder when i take it back off.
  25. #25
    Sep 2009
    Houstatlantavegas
    1,024
    Yeap, thats exactly what I did.
    -Jay
