When you say bolt, what do you mean?
The bolts that hold the wheels together?
Or the center "bolt" / nut. that holds on the cap?
The bolts that hold the wheels together, the RS are a bit different and not made for the style 5's. but people have been running them without problems.
The Center nut can be used as well, but it requires some modification. Some people modify the waffle as well so you can use it. There are a few guides around for this.
