I mostly lurk on this forum but am active on others.
I have a 2009 Infiniti FX50 that I've been wanting to lower. did springs on my last FX (05 FX35) and it wasn't low enough.
Now, I was to do coil overs instead of springs. Only available ones are BC or Megan. About $800-900 for the set.
However, the 09+ FXs have a camber "issue" (may not be an issue on here, but the usual FX guys don't want it) where when you lower the car even with springs there is already plenty of camber because there is not enough adjustment available stock, and there are no aftermarket camber adjustment kits.
Between the two brands, which do you think are better and do any of you know if there is a "cheaper" method to getting a camber adjustment kit. Quotes I've gotten varied from $250-900 for custom camber kit for my car….
I don't fully understand the suspension issue but there's only factory adjustment for TOE so when you lower it, there's nothing to adjust camber… and the coil over kits don't come with it (BC and Megan) and nobody offers custom adjustable camber arms or anything….
