Installed the stock crossmember and trans crossmember so I can fit up the L28, 5 speed and triple webers to make sure everything fits. Also need to fix a whole that was cut in the tunnel.
Cut out
Vroom vroom
Also had to put the tail light panel just to motivate me
Just got flares in he mail. These are my 15x9 Longchamps and as you can see once I lower the car the will tuck in a lot so I will be needing some much wider wheels with a large negative offset to make it look good.
You need to cut a SHIT load of fender out to fit the flares
