Results 1 to 20 of 20
Thread: Coilovers for e46 Xi
    Oct 2009
    Long Island
    2,680
    Default Coilovers for e46 Xi
    Having a surprisingly tough time trying to source quality coilovers for my e46 xi...
    question is: does anyone know if there are any differences between the physical suspension compoments on a 325 rwd vs a 325xi? we all know spring rates and such would be different because of weight etc.. im talking actual installation of components
    ideally, im looking at a custom valved set of BC coils for the DD, but i want to make sure the components are not somehow different..
    if i find out more info, ill post it up here.
    '93 na miata, '91 mustang gt, '16 GSW
    -recent past-e46t,e36m,e21,b6s4,tt225.....
    blog spinFAB.net store spinfab.bigcartel.com
    Jan 2010
    9,663
    Unfortunatley, RWD coilovers won't work on the XI. I've actually never been under an XI for more than 5 minutes so i cannot tell you the differences between the 2 models. I know the RWD e46 in and out so if you need any measurements LMK.
    I think there are better options than BC for the xi or any european car for that matter. I personally would not reccomend them to anyone, especially someone who has been around the best of parts such as yourself. Email, call or PM me and we can swap some ideas.
    Oct 2009
    Long Island
    2,680
    still really havent gotten too far with this. If anyone has any additional information, post up here.
    i would like to have the shop car lowered and on wheels for h2oi in a month ideally...
    from what i can see, the real difference is location of sway bar endlink.. which would not be a big deal at all. Ill just relocate the bracket to where it belongs if needed
    yeah im in the same position as you. i just bought an 02 325xi and i was looking for coils to buy. i was doing research on e46fanatics and they seem to think its crazy to lower an awd car...
    Oct 2009
    Long Island
    2,680
    yeah they are a primarily boring crowd.
    I am going to be working with Jaze to see if we can finally come up with some sort of answer as to if the e46 coilovers fit. From my research and getting under my car so far, the components look the same. its just where the end link on the sway bar mounts up. the end link is very long on the xi to clear front drive components.
    if thats the only difference, it will be an easy solution. Hopefully as soon as I get some time, I can discuss the options so people have a definite answer as to the differences between coilover systems for these cars.
    so far kits that say they fit XI
    k sport
    h&r
    KW v1
    ST something or other.
    not particularly a fan of any of these, so hopefully we can try to find a solution..
    i heard that you can use that 325 end links because they are shorter than the awd end links. let me know if you find anything out, i would love to be able to get a set of broadways
    Oct 2009
    Long Island
    2,680
    So... no news really to report, but I do need to get a set now asap. Blew out both rear struts this past weekend.
    going to start a thread for the car shortly since it is the shop wagon and it will be going through its share of wheel setups for next year.. Its first set of wheels was dropped off at the shop about a week ago, and instantly went into the chemical stripper.
    there's one guy on e46f i've seen with a low xi. His username is orisue46, maybe shoot him a message or something
    Instagram: @andrewgcross
  9. #9
    Jun 2009
    Tuusula, Finland
    1,350
    E46 Xi/Xd(europe only) (346X model) models got different kind of front struts, KW V1 is the "best" option for coilovers to these.. BUT there is problem with lowering these.. front driveshaft angles are bit weird and that causes problems.
    The front strut difference is on swaybar fitting. thats all i know about lowering E46 4wd
    And for the talk about "sets to fit" Xi model, if there is ANY other model than X model they probably don't fit 'sake of swaybar' other than that the lower part and the topmount seems to be the same..
    Now: Audi A4 1.8Turbo Quattro
    Ex:MB 190E M50, BMW E39 530d
  10. #10
    Oct 2009
    Long Island
    2,680
    Good info. Thanks for sharing.
    I too felt that when comparing the struts, the only difference seemed to be where the end link mounted up. That would be a very easy thing to remedy if this is the only difference up front.
    I think I'm going to buy a set of 325i or 330i specific coils and take the chance. I don't mind relocating the bracket if that's all it is. That would be cake
  11. #11
    Jun 2009
    Tuusula, Finland
    1,350
    Heres couple photos what i did my broken front struts...
    http://s970.photobucket.com/user/Exa...?sort=3&page=1
  12. #12
    Nov 2013
    Lebanon, CT
    80
    I have an e90 AWD and im kinda in the same position as you. I bought H&R coilovers, but they only go so low, and not low enough for me. I sourced a front linear spring mount, and was going to go with swift short springs, but i contacted H&R to see the max rates and shortest springs i could run. Max rate was 5k front 7k rear, and they also said i would be wasting my money because the shocks cannot handle short springs so they would basically blow right away.
    Luckily, Broadway static makes a set for the AWD E90, so after i get my wheels looks like i am going to start saving the 1600$ for a broadway static set up.
  13. #13
    Oct 2009
    Long Island
    2,680
    Thanks for the info guys. Jaze and I are in talks and I will likely have a set of broadways in the near future. I will keep everyone updated once I go to do the install and preparation and will document so we can once and for all figure this out. Im shocked with this being an approx. 10 year old platform that no one seems to take a chance to make options work for these cars....
  14. #14
    Oct 2009
    Long Island
    2,680
    bc coilovers have been purchased... possibly this weekend I will get the car up in the air and see how things fit up there.
  15. #15
    Hey
    How did thouse bc coilovers fit?
    I have a E46 330xd touring
    Give me a feedback =)
  16. #16
    Oct 2009
    Long Island
    2,680
    They are in a box still... Temps have been near zero here, and currently a foot of snow outside, so not much has been done just yet.
  17. #17
    Default Did they fit?
    In the exact same boat considering the exact same set up because of budget...were you successful with the BC's and what end links did you end up using?
  18. #18
    Oct 2009
    Long Island
    2,680
    They were on the car almost a year, required very little to make work (boring out the lower mounting holes up front) but otherwise bolted right up. Not a fan of bc to be honest after this experience, very budget coilover to be honest. Priced above it's quality factor from my experience.
    In terms of not working on an xi, there were zero issues with front axles or clearance. Wouldn't consider doing that again if I had the car
  19. #19
    Check out the K Sport Kontrol pro true rear coil overs for the e46 awd. I just got mine put on my wagon. They are great.
    http://i.imgur.com/WKKGqI4.jpg
  20. #20
    Quote Originally Posted by 1badg35 View Post
    how did you bore out the front mounting holes up front ?
