I want to slam my 1998 Forester but I dont want to spend to much on it. I was looking at impreza racelands and was wondering if they would fit my car? If not what will? Any help is greatly appreciated!
98 forester coils
buy the 02-07 Impreza specific Raceland coilovers. Make sure you put anti seize on the threads once you install them. Prevent the lock rings from seizing.
Here's an idea on how low they can go. This is my best friend's car
Rokkor/Raceland coilovers
18x9 Rota G Force +35
30mm spacers in the rear
1999 BMW M3
2002 Lexus IS300
2016 VW GTI
Wrong Fitment Crew #391
Rokkor?Hatchbacks, wagons... It's NOT all the same. You want in? Don't get a mazda 3, get a mazda 6 wagon. Don't get a wrx get a legacy wagon. and theres a reason the A3 isn't called the A3 avant... Scion does not make a wagon it makes a weird van, but no wagons
Sincerely,
The Wagon Mafia:Inner Circle
P.S. Is your tail a wagon?
Show cars are lame.
Originally posted by Wreckkid View PostI want to slam my 1998 Forester but I dont want to spend to much on it. I was looking at impreza racelands and was wondering if they would fit my car? If not what will? Any help is greatly appreciated!Instagram = VIP_E90
I just picked up a set of used tein flex for my 99 forester.. Has many miles on it, really used but dirt cheap.. If you're looking for something cheap check your local Craigslist or some of the forester or impreza forums.. Slammed my 99 with about 1" wheel gap from fender to tire... Camber is about -0.8* front and rear at the moment.. I'm rebuilding a set of 18" ssr Vienna kreis at the moment, so waiting for those then I can go lower.. Coilovers also came with edfc minus the main harness and harnesses from the unit to each corner.. But I'm sure I can make my own wiring harness...
Can't really say exactly how they ride as the fatty tires absorb most of the road bumps.. But the ride is firmer..
And the wheels I'm rebuilding
My exgf's bf, who is my friend but started dating my ex but i was okay with it since he was a man about it and asked for my blessing ahead of time, has a Forester originally he got about a half fist of wheel gap after putting on his old WRX's stock suspension, then switched to coilovers for perfect stance, his car is identical to the forester 2 posts up.
You can also use some Ebay coilover sleeves for a CRX but it WILL bounce like a bi%#h, however you'll never loose ride height when driving along, did that on my GL-10 in the sig below, im still finding lower struts fyi."Nord's armor has lots of fur. This sometimes makes M'aiq nervous." -M'aiq The Liar
THIS GL-10 IS PRETTY COOL!
Stay up to date with my '86 Subaru GL-10 build on Instagram with @billytheboobaru
"At least if your car is going to die, might as well die under WOT giving it the beans"
