They sound like absolute clowns.
Fenders rolled.. came out wavy. Fixable?
Originally posted by stinkinrich View PostThey sound like absolute clowns.
I just hope this quality doesn't show in their other work. Like I said, they're doing full air ride installs. I hope they do a good job for the customers sake. Would be a shame if something went wrong and caused an accident or whatever.
this happened to my old silver e36 they cracked the paint like someone said in the right hands with a roller and time and care and a bit of heat it could be sorted but i feel your anger they got some explaining to do stay with the guy this time when he put it right slowly slowly gently gently
Originally posted by 244Brick View PostSo did you ever fix your fenders bud?
I'm going to eventually down the road buy some new fenders, but right now its not at the top of my list. Its not bad as you'd think, no one ever notices unless I point it out to them. The angles of the pics make them a little worse than they are.
Rock Auto (rockauto.com)
2012 HYUNDAI GENESIS COUPE 2.0L L4 Turbocharged : Body-Exterior : Fender Price
VARIOUS MFR Part # HY1240149
{#663112M000}
Coupe; Left Front assy
$131.79
VARIOUS MFR Part # HY1241149
{#663212M000}
Coupe; Right Front assy
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$126.79
R.I.P P.WALKER 2013/11/30
{#663112M000}
$131.79
{#663212M000}
$126.79
Sorry to see this happen to you, it definitely sucks when a shop does sub-par work and then tries to pin the blame on you or play it off like "shit happens."
To the OP, I rolled my fenders myself. (my car is fairly old and never had good paint so I didn't care and would rather do it myself) I simply hammered the fronts in from the inside of the wheel well while applying pressure on the outside of the fender until the inner lip was flat. With the rears I went a little further and cut the inner lip out then rolled the fender with an aluminum bat. It came out fairly wavy at first but after playing with it for a few minutes I wound up getting both sides pretty straight and I was happy with the results. It sucks they fucked your fenders up, but if you are willing to put in a few minutes of elbow grease and aren't afraid of screwing it up you can probably straighten it out yourself and get them looking a little better for the time being. Just trying to help.
I've rolled fenders on a lot of Mercedes and they always come out looking clean but paint cracking/spidering and chipping will happen to anyone even the best shops. A good shop will always do a "dry run" and check where the roller needs to be adjusted. You have to do the fenders in sections because the arch isn't 100% round. Also if the heat up the whole fender before rolling they don't know what they're doing because by the time they get to the part they need to roll the fender already cooled down. You also have to watch how much heat you're applying.
That fender can be fixed with a fender roller, you just have to work on it in sections like I said. Always have to start from the middle and then to one side, some fenders are wider or narrower depending on direction.
You can hammer it out. I've had my fronts rolled for about a year now, no waves.
A while ago I got in a crash and a twig got between the fender and the tire. It was no bueno, thought I was going to have to buy a new fender. Even with the lips completely flattened and the fender pulled a bit I was able to hammer it completely out with a hammer and a rag.
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
Originally posted by Icana4dit View PostWhat shop did this?
Thanks for all the support guys, right now fixing it myself isn't a first priority, but down the road I'm def going to look into all the options, and see what can be done before going straight to new fenders
