Edit: Nevermind, I figured it out and answered my own question.
I have a set of Merc wheels that are 5x112 using 12mm lugs and I plan on putting them on my Passat that uses 5x112 14mm lugs. I'm good friends with a machinist so I had talked to him about having the holes drilled on the Merc wheels to be 14mm in diameter.
Q: Having them drilled wouldnt have any affect on the bolt pattern, right?
A: Correct, bolt pattern will not be affected because the centers of the lug holes are never changed. See diagram
