Redrilling?
  • Redrilling?
    Got 2 pairs of wheels
    One pair 5x114.3 ET43
    One pair 5x112 ET13
    Problem:
    If I make adapters I get ET-7 / ET23 respectivly
    Considering I will add some lips on "rear" ET43 I will move even under 0 mark.
    What are pros' and cons' for these?
    Sounds like offset isn't a huge issue here with the talk of 0 and negatives. Most people chose a redrill because they're either in a bind with offsets (any adapter would yield too much poke) or they dislike the idea of a bolt on adapter for some reason.
    I personally prefer not to alter original wheels because some previous work I had done left a bad taste in my mouth... If you DO decide to go the redrill route, I suggest researching the hell out of the shop you will have doing your work and looking for local examples of similar work they've done.
    Originally posted by AMGwheelwhore
    Quitters never stance.
      so either an adapter or something else... thats good to hear
        with that little of a change you can just use wobble bolts
