well thats the thing i took my helpers out and i let them settle in. its an ok drop but i feel like it should be lower compare to other mark generations on coilovers so i was thinking of cutting like maybe 2 inchs into the frame. and my car is white but ima wait till the spring. and maybe im thinking i gotta lower it because all the mark 5's have lips
MK5 on coils
Originally posted by maserat_E View Postwell thats the thing i took my helpers out and i let them settle in. its an ok drop but i feel like it should be lower compare to other mark generations on coilovers so i was thinking of cutting like maybe 2 inchs into the frame. and my car is white but ima wait till the spring. and maybe im thinking i gotta lower it because all the mark 5's have lips
so on a 17-19" wheel they would be just as "low" as you are
kinda sucks
I'm surprised there is no "chart" flowing around with the shortest shock/strut coilover assembly
I know that the FK one is A LOT shorter then a stock shock/strut
but this may vary between coilover manufacturers (which is why a chart would be nice - lets you see what you can use and decide how low you want to go)
Originally posted by M703 View Post
this is mine ok fk silverlines.. all way down in the front (helpers still in) a good amount in the rear left.
if your front is all the way down you can definitely do the rears!
my rear tire is tucked and my front is a little
just wait until Spring ... there will be a nice update
just wait until Spring ... there will be a nice update7VNZRO3
me? if so, this is my flickr. http://www.flickr.com/photos/mantonucci/ but thats the only picture so far with my current coil settings. i plan on taking more soon.7VNZRO3
Originally posted by powww View Post
fk silverlines 0 threads front and rear, notched
M703 - you can definitely have plenty of room to go lower in the rear, but maybe there is a difference between GLi and GTi
I love mine, I want front to tuck tire
how are your roads? hope you don't go "too low" for your roads there
hope you guys know what you are doing when you are getting that notch done
if you see air in your future, then definitely do it!
my front end is weird, I think its stock, but I have seen people rub like crazy and not be as low as mine is, I've yet to rub ANYWHERE in front or back, even at full lock
I do scrape like a madman pretty much anywhere I go, because of how the drive-ins into driveways and parking lots are made around here
powww - those are A8's right?
