Page 1 of 5 123 ... LastLast
Results 1 to 25 of 121
Thread: Slamboard? I think yes.
    Default Slamboard? I think yes.
    It all began when my friend showed me this slammed skateboard one day that was at some car meet and the moment we saw it we knew we had to get one. After weeks and weeks of lagging, we finally had a chance to make it! We decided we might as well post a thread on how to make one just for the hell of it, all in all it was fun making the boards! Enjoy!
    http://1013mm.com/blog/2011/09/kick-push-stanceboard/
    That was the one I saw. I'm not sure if he's the one who started it but I know there's lot of people who built it. Credits to whoever built it first and for the sick idea!
    What you're going to need:
    Skateboard deck.
    Pair of trucks.
    A set of skateboard/longboard wheels.
    Long screws and nuts.
    Coping saw.
    Electric drill.
    First of all, obviously you need a skateboard. Attach the trucks on top of the board the way you want it. There really isn't any difference facing the trucks in or out, the only thing that it affects is the distance between the wheels, probably a few millimeters difference. Take your wheels and roughly measure out how much you want to cut out, mark it with a pencil or whatever and get cutting!
    We chose to use a coping saw cause it was the easiest way we thought of. We first began cutting the two sides of the square we drew, and then used a drill to create a circle right on the border of the square to fit the coping saw blade inside. After it was in, cut on the corner and cut out the box! Continue the same thing for the 3 other boxes and you should have a skateboard with 4 square holes.
    The next thing we did was sand the corner with some P220 sandpaper to give it a smooth feel and look.
    Now that the skateboard has the holes cut out and smoothed out, it's ready for some trucks and wheels for fitment testing!
    After we assembled the boards, they looked amazing! So we went to go ride it around but..
    Ollies? Hahaha
    But.. we found out well.. that it was too low. Wayy to low; to a point where it was extremely difficult to ride. And because we used normal skateboard wheels, the ride was pretty rough too. Solution?! New wheels! Longboard wheels!
    The final outcome!
    The ride after we put on longboard wheels was completely different. It actually felt like a longboard kind of haha and it was a lot smoother. It's a few millimeters higher than it was before and now it's actually pretty easy to ride once you get used to it.
    Hoped you enjoyed this thread! Now go out there and make yourself a slamboard!
    Jan 2011
    London, UK - Belgrade SRB
    463
    Nice build, there is not enough poke and the tires are too fat IMO
    JC. Guest
    Want.
    May 2011
    Melbourne
    178
    What about some camber?
    Jan 2011
    Brantford, Ont
    510
    Im gunan be doin one of these again lol. Some fuckin Punk kid stole mine
    But nice work, i like the Normal Skate board wheels over long board but i might try them.
    JC. Guest
    How did you go about making the camber?
    Jan 2011
    Brantford, Ont
    510
    heat the axle up a little, Put a bolt on the end, use a hammer and tap it up till u have the camber angle u are looking for. U will also have to take a drill and make the inside of the tire bigger to clear the axle
    with long board wheel if u add camber u will burn the tires down a nice amount till u literally drag the board lol
    When i first did it, people though it was messed up that i cut up a 100$ Deck to make this
    Jul 2011
    Central GA.
    339
    I've got to make one.
    '88 323 - K-swapped
    '03.5 Mazdaspeed Protege
  9. #9
    Mar 2011
    redmond oregon
    386
    winning. this is what will happen to my old skate.
  10. #10
    Jul 2011
    Chadds Ford, PA
    6,178
    Gonna make one to roll around campus on. Bitchez go crazy ova some mad tyte skate boarders yo!
  11. #11
    JC. Guest
    fo sho ^
  12. #12
    Feb 2011
    Salinas, CA
    656
    Quote Originally Posted by mrg7243 View Post
    haha i was thinking the same thing
    Quote Originally Posted by cobrawannabe View Post
    More lotion.
    My build thread
    Instagram: Franswishaaa
  13. #13
    Jul 2011
    Chadds Ford, PA
    6,178
    Quote Originally Posted by siopaolover View Post
    plus it sets you aside from the other skate boarders
  14. #14
    JC. Guest
    Im making one out of a shovel
  15. #15
    Jan 2011
    Arnhem, Netherlands
    211
    when I'll get home from school today I'll make one asap of ye old board but I got a special paint surprise for it.. is it okay If I post the pics OP?
    BMW E30 316 Type 1 "Isabel"
    Quote Originally Posted by NickBroderick View Post
    I saw a stock height vette scrape into a restaurant parking lot when I was dropping off my brother for work. I then scraped a lot more than him and became happy.
  16. #16
  17. #17
    May 2011
    Melbourne
    178
    Someone needs to make one with a skid plate. What do you guys think?
  18. #18
    Quote Originally Posted by depuepedro View Post
    one of those boards is mine hahah. it's cool if you post yours! maybe we can make this thread something like a "calling all slamboards" or something like that!! i would actually like to see how other people are making theirs differently.
    ^^i dig the skid plate ideas!! gotta protect that oil pan! :P
  19. #19
    Jan 2011
    Arnhem, Netherlands
    211
    well it's just some chipped down old atm board I have for like 11 years now or so but I got some very nice plans for it!
  20. #20
    Quote Originally Posted by Obscevator View Post
    sweet!! i'm excited to see it!! imo, some things look better when they're all beat up and NOT perfect
  21. #21
    Mar 2011
    Spokane, WA
    808
    Ya I was gonna say...looks like my signature
  22. #22
    Yeah knock yourselves out, post pictures please! Get some more ideas in here haha the long board wheels make a big big difference I recommend them x-x
  23. #23
    Lol at the starfish hops!
  24. #24
    I'm gonna try to ride it around campus one day... and try not to eat it in front of everyone... well even if I do, my board is cooler than yours.
  25. #25
    Quote Originally Posted by Anonymoose View Post
    harhar
