what are the JOM fronts like? are the struts shorter than OEM?
Coil over settling??
Originally posted by Zic View Postpull out the pads and adjuster.
and by your sig, the car does not seem "slammed", lowerd yes, slammed no.
slammed in comparison to how it sits now.
oxer if i remove the springs, the axle will hit the chassis. and ride comfort will suffer immensely, and i got these to improve that.
i guess tonight ill just take out the stops and adjuster and see if that does anything. doubt it
yeah at least just run your already cut springs in the rear. no need to destroy a second set of springs. i would install the fronts, then run your cut springs in the rear and see if you like it. you can always look for shorter springs in the back later.
Originally posted by VicSkimmr View Postyeah at least just run your already cut springs in the rear. no need to destroy a second set of springs. i would install the fronts, then run your cut springs in the rear and see if you like it. you can always look for shorter springs in the back later.
If you wanted to go low and adjustable on the cheap you should've bought a cheap ass coilover conversion kit and some konis and made it work. Cheap ass coilover conversion kit for pretty much anything (75 bucks). Then actually spend some money where it counts and get some Konis(I'm sure you could get some for a couple hundred used).
JOM coilovers are exactly that except with shotty oem valved shocks, and huge springs. Might as well put that kit together the way you want with some quality shocks and springs that will get you the height you want.
Removing the collar will lower it exactly the same amount as the height of the collar lol no science in that man, and removing the stop won't help unless you sitting on them which you aren't at that height.
If getting your money back is an option, do that. 500 bucks on those...... damn
IG: @_olliee
Originally posted by Ollie View PostIf you wanted to go low and adjustable on the cheap you should've bought a cheap ass coilover conversion kit and some konis and made it work. Cheap ass coilover conversion kit for pretty much anything (75 bucks). Then actually spend some money where it counts and get some Konis(I'm sure you could get some for a couple hundred used).
then my car is slammed compared to a truck
500? thats a lot of money, if you want low on a e30 and have some decent travel. best option is what ollie said + cutting the front strut.-Instagram@jdjurhuus
Stretchsaurus and Pokemon.
Originally posted by Vegas13 View Postyea thing is now i cant afford to do anything. and this dude is being shady
I mean unless he assured you they'd go low or something..?
IG: @_olliee
Originally posted by Ollie View PostWho'd you buy em from? And why would he be obligated to give your money back? JW. Because I would say fuck off, lol you got what you paid for. No offense to you OP, but amiright?
Originally posted by VicSkimmr View PostI didn't realize your oil pan was near your rear suspension. To be fair to him, you haven't even installed the fronts to see how low they go.
i doubt that if the car is 2 inches HIGHER than the pan will be on the ground....
