Originally posted by projektzwo
View Post
wheel spacers. huge ones. i really need advice here.
Originally posted by ff_drift_lol View Postno no no guys, i am saying i can only order up to a specific size before they are non returnable and non refundable. i would like to get them a tad smaller than i measured and then add 5mm or so spacers to them for the option of going wider if i need to. but is adding a spacer to an already existing adapter a dangerous thing to do?
If it's worth doing, it's worth doing right.
Your blast pipes look stupid.
Originally posted by ff_drift_lol View Postvette wheels don't need to be, they have those conical lug nuts. the hub bore on my cobalt will be centric. i'm glad you pointed that out, most people would have never known.
Given the option, hubcentric spacers are always better, and giving them a flange for hubcentric wheels to sit on is even better. If I could do it over again, when I ordered my spacers I would have ordered them to be milled hubcentric to a common factory hub size so I could use hub centering rings to mount wheels.
Originally posted by cardoza View Postbut why not just order the size you need in the first place?
It's hard to know exactly how much mm he will need.
If the adapter/spacer comes up a bit short he will have to add another spacer on top of that which i don't think he wants to do.
And those adapters/spacers cannot be returned since they are custom ordered.
Spacers on top of adapters is a pretty bad idea...
Sure it could end up being harmless in a year of driving around. Or... you could go flying off a bridge the first bad pothole you hit.
I need to buy adapters for my e30 and I'm going through the same issue - high offset corvette wheels. Just do your homework and calculations the same way anyone else does, should end up with the right number if you do it right. I'm actually scared to death of running 25-30mm bolt on adapters by themselves.4 Cars, 0 Cupholders
order the adapter and some spacers, bolt it up until you find what you like. Measure it... order the correct size adapter and then sell off the ones you bought.E53 4.4 Sterling Gray Metallic
E36 M3 Mugello rot
GEN2 TUNDRA CM
https://instagram.com/carlmichaeljohnson/
