Results 1 to 12 of 12
Thread: Widebody Hardbody
    Sep 2019
    Seattle WA
    12
    Default Widebody Hardbody
    We're going to jump into this project in medias res. This started in February of this year when I got an $800 landscaping truck, 2wd four cylinder 1987 king cab Nissan D21.
    SAM_3244
    SAM_3250
    SAM_3243
    As it stands now it's been painted, I've made a custom flat bed and roll bar and a custom rear bumper. The rear end has been swapped to a 10 bolt 8.6 inch from a 2009 Chevy Tahoe that has been rebuilt with 4.56:1 gears and a Yukon limited slip diff. The rear end had all the stock bracketry cut off for it to be perched on Old Man Emu heavy duty leaf springs. At some point in the future I might go to a triangulated 4 link in the rear, but until it's driving the rear suspension is done.
    SAM_3255
    The track width is a full 13 inches wider than stock and the tires are tucked under trailer fenders in the rear that stick out about 5.5 inches wider than the stock body. The wheels are 17x8.5s from a Toyota 4runner just to confuse people with the Toyota logos.
    SAM_3248
    The bed and bumper are made mainly of 3x2x.120, 2x2x.095, and 1.5x.120 round A513 tube.
    SAM_3252
    SAM_3253
    Up front the stock engine and transmission have been pulled and I've started cleaning up the engine bay to prepare for the swap.
    SAM_3257
    SAM_3259
    For the new powerplant I'm in the middle of rebuilding an LQ9 6.0L out of a 2004 Escalade, the plan is forged pistons, a fairly aggressive cam, and bigger injectors. Should be good for around 400 HP. For the transmission I have a CD009 6 speed out of a 2008 G37 that I will adapt using the Collin's adapter and a T56 bellhousing, that way I'll still have a little bit of Nissan at heart, haha.
    IMG_20190902_170719388
    SAM_3224
    SAM_3232
    I've still got a long ways to go, but the plans to finish it are: Fiberglass front fenders with a 4" bulge. Make custom A arms up front that are about 6 inches longer per side and going to a coil over shock to get the torsion bars out of the way of the exhaust. Front steering knuckles and brakes are going to be modified unit's from a 2018 Silverado. I'd also like to convert to a rack and pinion but planning on that particular item hasn't gotten very far yet.
    The transmission tunnel is going to have to be clearanced somewhat to fit the new bigger bellhousing, depending on how low I can set the engine. The plan is to get pretty low with the oil pan from a CTS-V and making a custom front crossmember. I also need to make a matching front bumper.
    Sep 2019
    Seattle WA
    12
    Going back in time, this is how the truck looked when I got it.
    IMG_20190202_115547645
    IMG_20190202_115538324_HDR
    This first modification was the wheels and tires.
    IMG_20190216_131642957_HDR
    And two months after that I chopped 18 inches off the frame to start making the flat bed.
    IMG_20190427_133026556_HDR
    Apr 2014
    San Diego, CA
    22
    This thing is sick!
    What's the end goal? Will you keep it off-roady with the knobbier tires, or make it more of a fast street/drag truck and swap the tires? Either way I love it and I'll be keeping an eye on this one
    Sep 2019
    Seattle WA
    12
    Ideally I'll be able to have a set of street tires and a set of off road tires. Traction is definitely going to be an issue with 29" tall tires and 4.56 gears because I initially picked that ratio to suit the stock motor with something like 80 horsepower.
    I see this thing being used for bombing down fire roads, but it should do some pretty good burnouts.
    Definitely one of the coolest builds I've seen. cant wait for updates.
    Sep 2019
    Seattle WA
    12
    Continuing our trip through the past with the fab work on the bed.
    This was setting the ride height of the bed frame.
    IMG_20190504_130556963_HDR
    Making all the cross members.
    IMG_20190505_144257930_HDR
    IMG_20190505_134840841_HDR
    Bed mounts.
    IMG_20190509_160546299_HDR
    Flat bed on the mounts for the first time.
    IMG_20190509_172428357_HDR
    Main hoops for the roll bar.
    IMG_20190512_182055818_HDR
    IMG_20190518_134359636_HDR
    Fabbed the bumper in place on the truck.
    IMG_20190519_100330089_HDR
    IMG_20190526_155947057_HDR
    IMG_20190526_173118778_HDR
    IMG_20190526_173218260_HDR
    And when I first got the fenders mounted and it started looking like a truck again.
    IMG_20190531_184044747_HDR
    IMG_20190531_202318053_HDR
    Sep 2019
    Seattle WA
    12
    I've been largely just collecting parts recently, but I finally have everything I need to take my block to the machine shop.
    The block has been totally stripped down.
    _DSF7029
    _DSF7033
    _DSF7035
    The stock forged rods have been cleaned up.
    _DSF7039
    _DSF7028
    I got a new set of 0.005" oversized flat top forged pistons with valve reliefs.
    _DSF7045
    And finally a new Lumpy Boi. This is Summit's stage 3 truck cam.
    _DSF7052
    IMG_20190927_163816715
    Not pictured is about $500 in ARP fasteners. I got head bolts, main cap studs, and rod bolts from them.
    I'll leave you with some fun night rain shots of the truck.
    _DSF6936
    _DSF6931
    Aug 2016
    N.Ireland (Norn Iron)
    289
    Wow!!!
  9. #9
    Looks like more an Australian's UTE now.
  10. #10
    May 2013
    Gainesville, FL
    96
    I love your fab work, but I have to say I'd rather see it with prerunner-style fenders and bedsides.
  11. #11
    Sep 2019
    Seattle WA
    12
    Quote Originally Posted by Asshole Bicycle View Post
    It is getting prerunner style fender up front. In the back I kind of always wanted the utilitarian flatbed. Plus I've never seen anything like this and there's tons of full glass prerunners out there.
  12. #12
    Sep 2019
    Seattle WA
    12
    Some minor progress, I've taken the LQ9 block to the machine shop. They're pretty swamped so it'll probably be January before I get it back.
    I figured people would enjoy this picture of me loading it into my work truck. She was riding pretty low that day.
    DSCF7462
