Results 1 to 3 of 3
Thread: Question about clear coating
    Default Question about clear coating
    Hey guys, I picked up a set of OEM wheels for winter at a fair price. They have some curb rash and scratches, some of which are pretty deep. I'm spending a little bit of time stripping the clear, sanding down the damage and trying to restore them to their original finish.
    I understand that clear coat won't stick well to a polished surface. The wheels originally had a semi-polished face and were clear coated from the factory. What grit of sandpaper would you recommend stopping at before having them clear coated? In the photos below, I've gone up to a 2000 grit and wet sanded. Thanks for your time.
    Dec 2013
    Seacoast, NH
    378
    You can clear coat polished lips. OZ & BBS OEM lips come polished with a painted clear coat on them from the factory.
    Jul 2019
    anywhere usa
    19
    Powder coating clear will adhere to alloy wheels a lot better than paint. It however can be hell removing, sandblasting or Airplane stripper can be used or acid dipped.
    RH ZW4 Wheels polished and fresh Clear Coat by Richard Baumgarten, on Flickr
    independently owned
