Results 1 to 9 of 9
Thread: Need help with set up...
  1. #1
    Join Date
    Mar 2018
    Posts
    101
    Default Need help with set up...
    I keep thinking I have this figured out, but then a wrench gets thrown in..
    My car runs 5x115 Wheels. I have 20x9 on it now.
    I'm putting a wide body kit on my car and this is where I have my issues.
    A wheel company has offered to give me a set of custom offset wheels, but they don't offer my bolt pattern anymore. They do offer 5x114.3.
    I want to be able to run my current wheels and keep my new wheels for Shows only.
    So here is what I have figured or found out. 5x114.3 fits, but isn't recommend due to stress on the studs. So I thought about re-drilling my Hubs and rotors to 5x114.3. This sucks b/c every time I have to change hubs or rotors. I have to do it again. It's not an off the shelf repair. I have to Adapter Spacers anyway to run my current 20x9 5x115 wheels for daily use. So thats not a huge issue.
    My other option was to run wobble nuts and centering rings. But my studs are M14 and these are only made in M12.
    I really don't want to run Adatpers to run my New Show wheels, b/c it will reduce the size of the Lips.
    Also thought about redrilling my Wheels to 5x115. but the wheels have a dual pattern pre-cut in them. So that doesn't work either.
    What can I do here?????
    2010 Dodge Charger - Soon to be Wide body
  2. #2
    Join Date
    Jan 2012
    Location
    at the shop
    Posts
    1,409
    Default
    Quote Originally Posted by Ramrod View Post
    If a company can offer custom wheels with offsets, they should be able to offer custom pcds...
    Option 1: Have studs made that fit your hub but are M12x1.5.
    http://www.msirp.com/custom-single-ended-wheel-stud
    Option 2: Redrill new wheels to 5x115 with inserts.
    http://customwheelaccessories.com/al...l-inserts.html
  3. #3
    Join Date
    Mar 2018
    Posts
    101
    Default
    Quote Originally Posted by OrangeBlue View Post
    You would think they would, but they don't.
    By redrilling the wheels. Is that just basically opening up the 5x114.3 holes bigger and inserting the inserts to make it a 5x115?
    Both seem like great ideas.
    Thanks for the links.
  4. #4
    Join Date
    Dec 2012
    Location
    PDX
    Posts
    605
    Default
    I would go the route of switching to 12mm studs and using wobble nuts. It would really open your options for 5x114 wheels and still be able to swap back to stock. Redrilling (inserting) is also an option, but changing studs is more DIY friendly.
  5. #5
    Join Date
    Mar 2018
    Posts
    101
    Default
    Quote Originally Posted by KyleAnderson View Post
    This is what I'm think as well.
    Thanks
  6. #6
    Join Date
    Mar 2018
    Posts
    101
    Default
    Came across these..
    https://www.aliexpress.com/item/1PCS...849631847.html
    Are these Wobble Nuts?
    Is this normal for variable PCD Nuts.. No Air Impacts can be used on them?
  7. #7
    Join Date
    Dec 2012
    Location
    PDX
    Posts
    605
    Default
    It doesn't say they're PCD variation, so I wouldn't count on it. As far as I know, they don't exist in 14mm.
    Not using an impact is normal for all lug nuts. They should be torqued by hand.
  8. #8
    Join Date
    Jan 2012
    Location
    at the shop
    Posts
    1,409
    Default
    Maybe these guys can help you out.
    https://spurverbreiterung.de/index.p...-elements.html
    They don't have them on their side but asking is free...
  9. #9
    Join Date
    Mar 2018
    Posts
    101
    Default
    Thanks Everyone... I've tried getting in contact with MSI, waiting to hear back. also contacted Moser Eng. and one other company about new Wheel Studs.
    Currently Talking with Giovanni on a set of Solid Fury wheels in 20x10 -13... I can make these work on all for corners pretty easy.. They don't have a massive lip in 20x10, but will still look great under a wide body. I could still run my 275/315 staggered set up or run 305s on all four if I want. I would need just 1in Adapters to fit. Gives me a little room to adjust and play with...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
