Results 1 to 3 of 3
Thread: need help with my Poor Man's build
  1. #1
    Join Date
    Dec 2017
    Posts
    15
    Default need help with my Poor Man's build
    so.i would like to bag my e36 compact on a budget...will this Air Ride Suspension Manifold work ok?
    https://www.ebay.com/itm/Air-Ride-Su....c100005.m1851
    and if i can save the high,normal,slammed settings?txn
  2. #2
    Join Date
    Dec 2017
    Posts
    15
    Default
    I dont want to spend to much money on sistem management..i even dont need every corner for it self..just front and back..so i can lift it on speed bumps and lower it back down
  3. #3
    Join Date
    Feb 2018
    Posts
    6
    Default
    are you planning on monitoring the PSI level on all 4 corners, if so what are you planning on using?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
