LoweredSilverado
  • LoweredSilverado
    Little introduction about me Im TJ. I got a 92 Silverado with a 86 front clip(because previous owner believed in junkyard parts). Its got a 305 small block(With minor throttle body problems). Soon to be lowered and side skirts/wheel arch extensions added.
    Hopefully y'all enjoy this build as much as me.
    excited to see more. believe you meant 96 front end, 86 would be square body. nothing wrong with junkyard parts either!
    Originally posted by BozoBubble
    Stance bug bites hard, man, you ain't gonna shake it.
    Truck Build
    Instagram: somestancekid
      That looks like a seal quad beam 88/89 front end. Nice GMT400, I've got a 1998 Tahoe.
        Nice start.
        Love me some lowered Silverados.
        What are your plans for it?
        Had a 99 Tahoe, now have an 07 Tahoe. Waiting to be dropped haha.
          Yay lowered truck! I’m totally down for this. Would really like to see a full shot of the truck, if you have one.
            +1 on this, I'm a big fan of slammed trucks
              What's your cab size, box length? Always a fan of seeing this gen chevy truck on the ground.
              [CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
              [img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
              Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
                Originally posted by sqznby View Post
                Nice start.
                My plans are to lower it obviously. Im also looking for a 305 small block.
                  Single cab, short bed.
                    I don't have one at the moment. But will be doing a photo shoot with the truck soon.
                      Obviously.
                      I guess I should've been more clear. What specs are you going for and how are you going to get there? Coils/spindles up front and leafs, flip or linked out back? How low?
                      You could probably find a 350 for short money.
                      Why side skirts?
                        Obviously.
                        Why side skirts?
                        if you are looking to get low cheap axle flip would be the way to go. dont get a 305, they are better as boat anchors when you can get a 350 for about the same price. im lowered 4.5/5.5 (roughly) in my s10. cut coils, spindles, tall balljoints in the front and blocks, pulled leaf, and set back/ angle plates in the rear. im in about $350 but my way of lowering it is the cheap and honestly shitty way. axle frame bangs and wraps like a bitch causing wheel hop, while the front bottoms out constantly because there is no progressive spring rate. save yourself the irritation later and get springs, and spindles for the front (tall balljoints if those are also associated with c/k trucks) and actually get leafs for the rear after flipping your axle. use blocks as a means of dialing in rather than a first resort for getting low.
                        Truck Build
                          Obviously.
                          Why side skirts?
                          Just mild low, Cutlass springs up front, and I'm taking a few leafs out of the back. And side skirts because they cover the rust around the wheel wells.
                            The person before the person I bought it off swapped it from a v6 5 speed to a 305 automatic trans. And as I responded to sqznby I'm just doing cutlass springs in the front and taking a few leafs out the rear
                              A 350 will bolt up to either of those transmissions and a 350 will drop right in the mounts. Just because it has a 305 dosnt mean you have to get another. I believe a 305 ecu will just plug in and run a 350 if they are both throttle body injected. As for lows be careful when taking leads out in the rear. Especially with a v8.
                              Truck Build
