I'm attempting to remove the centers from a set of Work wheels. The lips and barrels are welded. The dumbass who refinished them previously siliconed the faces in. I've tried a heat gun, WD-40, pressing it out with a scissor jack under my work bench. Got one soaking in PB Blaster over night, but I'm not hopeful. Anyone here had success in this situation, or have other ideas?
Tips for removing stuck center, siliconed to lip?
Originally posted by OrangeBlue View PostShop press?
Usually Silicon isn't that strong.., can you get in there with a knife or something?
I was also considering a shop press. My concern is possibly damaging the lips, since presses don't usually have large support plates. The problem I see with the silicone is that usually it's a shock force that breaks the center free, but the silicone is absorbing the shock. You're probably right that they'll need to be pressed out.
