I have for sale a PROJECT e38 that is bagged on the best air bag/air management system money can buy. Air Lift 3H/3P management. I paid over $3000 for the entire kit. I am up front and honest, I am in escrow on a house and need the project gone.
I have installed all 4 air struts on the vehicle already. I already did the hard part of machining down the front strut inserts to make the e39 kit work on the e38.
The following is needed to complete the project:
Remove the front sway bar
Plumb air lines to trunk
Wire compressor
Reassemble rear interior
Install height sensors
That is basically it. Not much else is needed for the project. The car will roll with wooden blocks under the control arms so you can get it on a trailer. I can most likely tow it for an added or negotiated fee.
The car runs awesome. It hasn't started in a little bit but ran great before it was put on jackstands. Everything in the car works. Slight leak from unknown area. Black on black, great condition.
Alpina front spoiler
Alpina steering wheel
Aftermarket exhaust (sounds amazing)
I have receipts for water pump, timing chain, valley pan gasket, head gasket, abs module, master cylinder, front brakes, and tires.
Clean title, comes with everything needed to finish the project.
It will be amazing once finished. Comes with M parallel wheels.
3000 cash or best offer. I will not split up the air package, it is basically all on the vehicle. Again, I spent way more than 3000 on the air package itself.
Located in Sacramento. Call/text 916 673 7364
Paul
Wire compressor
Paul
