FS/FT: 1996 Nissan 240sx
  • FS/FT: 1996 Nissan 240sx
    I'm looking to sell my '96 240sx, not in a rush to sell so if you aren't going to offer something close to my asking price don't bother contacting me. The car is set up to drift and has a S13 Redtop SR20DET swap in it that I did myself. The engine was purchased from JDM Engine World in New York City and has great compression. I completed the swap and have only put about 300-400 miles on the car since then, it has never seen a track day or been drifted on since the swap. The car has a full custom chassis wiring harness that has basic essentials (headlights, taillights, gauges, ignition, fans, and start). There is no AC, heat, power windows, etc. all of that has been removed from the car. The car is not painted currently, but the longer I own the car, the more things will be done to it. Alignment was done about 3 weeks ago (4/6/17), I have the spec sheet in the car. Title is clean and in my name. Below is everything listed on the car:
    Engine:
    S13 Redtop SR20DET
    PBM High Mount Intercooler
    Mishimoto Radiator
    ISR Dual 12in Electric Fans
    SPEC Billet lightweight flywheel
    SPEC Stage 3 Clutch Kit
    ISR V2 Exhaust Manifold
    Stock T25 Turbo with 12psi boost
    HKS Actuator Kit
    RSEnthalpy ROM Tuned ECU (pushing about 260whp)
    ISR Turbo Elbow
    ISR Downpipe
    ChaseBays Power Steering kit
    ChaseBays Brake Line tuck
    Apexi Intake
    ISR Fuel Pressure Regulator
    Circuit Sports Catch Can
    WiringSpecialties engine harness
    P2M Poly Engine & Trans Mounts
    Suspension/Brakes:
    ISR Pro Angled Tension Arms (less than 200 miles)
    Fortune Auto 500 series 14/12k Coilovers (less than 200 miles on them)
    Q45 inner and outer tie rods (less than 200 miles)
    30mm Extended Front Lower Control Arms (less than 200 miles)
    New OEM Pads and Rotors
    ISR Rear Upper Control Arms
    ISR Rear Toe Arms
    Welded Diff
    Full 5 lug swap
    ISR Stainless Braided front brake lines
    ISR Stainless Braided clutch line
    Body:
    2F Performance 50mm rear over fenders
    DMAX 20mm front fends
    VIS body kit
    Euro Glass Headlights
    Tube Front End by AlexanderFabrication (there was no damage to the car previously, just did it for ease/looks)
    Hood Pins
    Wheels are Weds Kranz Cerberus II, 18x9.5 and 18x10.5 with brand new 235/40 and 255/35 tires (the pictures below show worn out front tires from different wheels)
    Interior:
    Custom gauge cluster made by MA Motorsport
    AEM Wideband Gauge
    Tanabe Water Temp gauge
    Boost Gauge
    Oil Pressure gauge
    RPM Gauge, no speedometer
    Stock S14 Seats
    Grip Royal Woodgrain steering wheel
    Sonic Motorsport Harness bar
    I have all interior pieces that are not currently in the car (door cards, rear seats, climate control module, blower motor, etc.)
    My asking price is $11,000, I'm also open to trades of the same value or you can add cash on top. I'm sure there are a few things missing from the list, but I never took any short cuts when building this car. Please contact me if you have any further questions, thank you.
    Matt
    This is the only picture I have of the car right now, I will be updating with more engine bay pictures and such.
    IMG_3473 by [url=https://www.flickr.com/photos/123784670@N07/]
    Instagram: @mattragsdale
    '97 M3 build
