View Full Version : Torque Specs for Fittipaldi 500's?
boligrafo123
08-21-2009, 01:16 PM
Anyone know where I can get the torque specs for my Fittipaldi Modular 500's?
1985zcar
08-21-2009, 06:31 PM
Like... for the bolts that hold the wheel together? I did 20ft lbs on my friend's OZs.
Tuck&Poke
08-21-2009, 06:36 PM
i think 20-35 ft/lbs is ok
id pick a number in the middle and do that
Russell_G
08-26-2009, 01:20 PM
2 piece wheels usually 20-25ft/lbs and 3 piece are usually 30-35ft/lbs. Thats using new bolts or bolts and nuts. If you reuse bolts you cant tighten them as tight. Also do 2 steps. 1st step 1/2 the finishing tq in a star pattern.
Digitalwave
08-26-2009, 03:45 PM
This.
On my RSII's I put a drop of Loctite on the bolt, then threaded them all in a star pattern starting at 12ft/lbs. Then I went back around in a star pattern at 24ft/lbs.
1985zcar
08-26-2009, 07:33 PM
Well you have a lot more patience then me hahaha
low_offset
08-27-2009, 11:04 PM
usually in used bolts you can go with 24lbs but depend on the bolts too. For example the bolts that use Gotti wheels only hold 12lbs but the RS bolts holds from 20-30 lbs easily because of the nut :confused
Digitalwave
08-28-2009, 08:02 AM
RSII's only have 16 bolts each so it wasn't that bad.
boligrafo123
08-29-2009, 07:07 PM
Thanks for the help guys.
As of today, the wheels are assembled and awaiting tires. :)
Edited for a little teaser:
http://farm4.static.flickr.com/3509/3868018459_481fbb6fb4_m.jpg
Digitalwave
08-30-2009, 08:47 PM
Fuck yeah!
SeanDub
08-30-2009, 09:14 PM
This looks great
schroedin
08-30-2009, 10:53 PM
Holy hawt.
