View Full Version : lower on one side?
staytuned05
07-06-2010, 06:03 PM
heres the issue....
05 Altima 50xxx miles
Tein basic coilovers
all rings are spun all the way down
ride doesnt seem affected
but my driver rear looks lower then the passenger rear. just slightly. am i on drugs?
RedE46Bimmer
07-06-2010, 10:04 PM
Mine are lower on the passenger side as well. But somewhere I heard E46 are just like that for some reason. Don't know about Altimas though.
lowpoke
07-06-2010, 10:16 PM
gas tank dude, it does the same on my s4 and friend jon's s4 and its because of our gas tanks, probably true with yours too brandon
RedE46Bimmer
07-06-2010, 10:27 PM
Good point. Never thought of that.
But then again I try not to :rofl
NegativeCamber
07-06-2010, 10:32 PM
not exclusive to the e46..alot of bmws are like that. supposedly the weight of the driver balances the car out.
primerdimer
07-07-2010, 12:51 PM
Yea isnt the battery on the passenger side for BMW's? That is probably the main issue.
HFe36
11-11-2010, 09:23 PM
I have the same problem as well. but my front passenger side is lowered then the drivers side. its weird because the passenger side is up 3 revolutions and the drivers side is 1. yet, the passenger side sits way lower? can anyone help me out please
firelizard
11-12-2010, 09:56 AM
Raise the passenger side more.
Oxer
11-12-2010, 10:04 AM
If you can see under your car, its not low enough ;)
HFe36
11-14-2010, 10:39 PM
i did that. but does it matter if its not matching the other side?
Bonka
11-16-2010, 07:19 PM
All cars are like that. On my car each corner has different adjustments. It doesn't matter to a degree unless the adjustments from side to side are so far off that one side is more likely to bottom out first.
Best way to get as close as you can would be to break out the measuring tape and adjust the car on the same flat surface.
HFe36
11-19-2010, 02:39 AM
I took out the perch on the rear and it didnt even look like it got lower looks the same. also, now the left rear side looks higher the the right passenger side. is their something wrong?
