View Full Version : Toyota keeps Dying??? Help
Stolzy
08-07-2009, 02:56 AM
Ok so I own a 1972 Toyota Carina. It has the same 4 cyclinder 1.6 as the Corolla from that year.
Anyways onto the issue. The car starts fine and idles well for about 10 sec. until itll go to die so i tap the gas and it wakes back up. So I just put it in gear and get going as it doesnt die when on the gas. and then...when it comes time to stopping, if I were to just put the car in any gear including nuetral and slow down it'll just die. But starts right back up after??? And this happens all the time. It used to be like once or three times a day but now its all the time. I drive the car maybe 30 miles a month or so but if it didnt have this problem id drive it a lot more.
I've tried adressing the issue and have so far
-cleaned the carbuerator
-replaced the spark plugs
-new fuel filter
and still nothing helps. My friend thinks it's the altrenator and im thinking that or the carb...idk
if you have any ideas or experience. PLease HELP
Thanks
bataangpinoy
08-07-2009, 11:21 AM
you have what would be a vac leak for me. if your not on the gas, it dies righyt? does it sound bad or idle rough?
hootie
08-07-2009, 12:11 PM
Have you checked the idle cable and made sure it was tight?
This happened on my uncles 1974 BMW 2002, and that was our fix.
Stolzy
08-07-2009, 12:28 PM
interesting, ive posted this on 2 forums...both saying it may be a vacum leak and i never thought of that haha
Yes, it dies when im not on the gas and idles bad most of the time but sometimes itll be fine but ill still die when slowing down.
Thansk
handsome.garage
08-07-2009, 12:36 PM
does it happen when cold or hot? or both? if i remember correctly, it can be the vacuum line for the choke. or trying adjusting the idle screw.
Stolzy
08-07-2009, 12:49 PM
it happens mostly when cold. but sometimes less when hot
Stolzy
08-07-2009, 04:27 PM
whats the best way to checck for a vacuum leak?
Dutchy
08-07-2009, 04:39 PM
start the engine and listen for a leak. Look for broken vacuum lines.
handsome.garage
08-07-2009, 08:46 PM
an old school trick, although not as reliable is to lightly spray or mist brake cleaner around where the vacuum lines are to temporarily "seal" them and listen to the engine carefully for differences. usually if theres vacuum leaks and the brake cleaner seals them you'll notice a difference with the motor's sound.
its been awhile since i worked on one of those motors, 2tc right? fuck if you were closer i would help, but its hard explaining things on the internet.
Stolzy
08-08-2009, 03:59 AM
thanks for the advice. and if your ever in the area hit me up and you can take a look haha. i might be driving the car down to san diego soon actually as i'll be going to school down there and maybe driving down 2nd semester...idk haha
